Any info about inductors?
  • Logistics
    • Apr 2007
    • 721
    I was wondering if any benefit could be seen by changing inductors on motherboards. Obviously, it's possible to get different winding configurations and core types; many having much lower DC resistance for a given rating in Henries. Any thoughts?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Any info about inductors?
    The heat dissipated in an O/P inductor comes from two major sources. One is the DC resistance. The other major source is the AC loss of the core, which has to do with the AC flux density, the switching frequency and the loss characteristic of the core material. You also have to be careful of the core's characteristics with DC current. Here is Micrometals's site, which has a lot of general info and info about their powdered iron cores. Here is the webpage for Magnetics Inc.'s MPP, High Flux and Kool-Mu cores. And here is the webpage for Metglas amorphous metal cores. Determining which type of core is used on your MB won't be easy. If the inductor isn't too full, you may be able to use the original core and rewind it to get more copper. Count the number of turns as you remove the original wire and determine what gauge of wire it is. If the original wire is AWG #10, winding the same number of turns with two strands of AWG #12 bifilar might increase the amount of copper without exceeding the window area of the core (it should also improve what is called "skin effect" in which high frequency AC current tends to flow in the outer part of the wire).
    PeteS in CA
    • 999999999
      • Sep 2006
      • 774
      Leave the inductors, they are matched to the circuit and there should not be enough loss to overheat them, and only a small increase in efficiency if you could reduce that loss which is kind of trival when considering an entire (computer?).
      A better reason to change one would be if it's resonating and you find the noise objectionable. Then again a coating of epoxy over it is a lot easier and quicker.
      • Wanderer2467
        Unsure if missing components are inductors on Gigabyte Z490 Aorus Elite AC
        by Wanderer2467
        Hello all.
        I am trying to repair a Gigabyte Z490 Aorus Elite AC motherboard that was roughly handled. It had some components ripped off the bottom of the board. The last two I am trying to replace are shown as CKA_FB1 and CKA_FB2 on the schematic and I think they are SMD 0402 30nH inductors to control the resonant impedance of the control rails. I have measured approximately 3.3VDC at CKVDD as per image below. On the board the still in place CKA_FB3 is 1mm x 0.5mm SMD component with a dark body.
        I am not familiar with the symbols used in the schematic below if anyone...
        05-11-2024, 03:23 AM
      • sony855
        about resistance help 2 inductors that have different values
        by sony855
        Hello !
        I would like to ask you . How I can learn the exact resistance value of each component. Im talking about laptop motherboard. I have 2 inductors that have different values one is 0.200k om other one is 0.100 kom . Thanks . How to know which value is good and which one is not goof. Thanks
        02-05-2024, 03:03 PM
      • redbaron1007
        Liquid damaged macbook A1466 fan spins, but doesn't turn on.
        by redbaron1007
        I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
        10-24-2024, 05:45 PM
        Phase Loss Monitor having false triggering ( bad capacitors issues)
        These phase loss monitor modules have two boards one board is basically the power supply board the other board is basically the phase loss monitor circuit
        It has three capacitors on it one on the power supply board 470uf@50volts (KMG) 0.11 ESR value
        The other two capacitor are on the phase loss monitor circuit board
        One capacitor is 10uf@63volts (Unknown brand) replacement capacitor automotive grade low ESR
        One capacitor is 100@50volts ( unknown brand) replacement capacitor was 100uf63volts automotive grade low ESR
        The results of the ESR are...
        06-07-2020, 06:48 AM
      • conghuyms
        Issues leading to the loss of 1.8V EN on the RX5700XT graphics card
        by conghuyms
        Hello everyone.
        I’ve seen many questions related to the 1.8V EN power rail on the RX5700XT graphics card. Could everyone help gather and summarize the different cases where this power rail is lost? This would help members and readers more easily troubleshoot and fix similar issues on their own cards in the future. Thank you all!
        As for me, I encountered this issue when the 1.8V EN rail was lost due to a faulty transistor Q10021. Are there any other possible cases?...
        07-08-2025, 09:49 AM
