about resistance help 2 inductors that have different values
  • sony855
    • Feb 2021
    • bulgaria
    Hello !
    I would like to ask you . How I can learn the exact resistance value of each component. Im talking about laptop motherboard. I have 2 inductors that have different values one is 0.200k om other one is 0.100 kom . Thanks . How to know which value is good and which one is not goof. Thanks
  • jkucukov
    PS3 FAT NEC/TOKIN Resistance Testing, need help interpreting values
    by jkucukov
    I'm in process of diagnosing the yellow light of death symptom on my PS3 FAT console CECHG01, in process of getting the Arduino gadget to be able to access Syscon and be able to read fault codes. In the meantime, I'm trying to measure resistance of the NEC/Tokins while still attached to the board. I took the Ohm readings from each of the NEC/Tokins from front and back of the board (4 from the RSX and 4 from the CPU chips).
    What I gathered in the attached pictures are values from the CPU NEC/Tokins are consistently measuring 1.6 Ohms while on the RSX they measure 3.4 Ohms except for...
    10-03-2025, 03:20 PM
  • kurzweil
    Looking for resistance values ​​on the motherboard of an HP EliteBook 840 G5 (BIOS area)
    by kurzweil
    I'm currently repairing the motherboard of an HP EliteBook 840 G5. The photo below shows the area around the BIOS chip (MXIC MX25L25673GZ41-08G).
    Unfortunately, I'm missing the resistors circled in yellow and blue. Could someone tell me the values ​of these two resistors, or where I can find a suitable schematic or board view?
    Thanks in advance for any help!​...
    10-30-2025, 07:35 AM
  • cind12
    GTX 1080 TI Gigabyte Aorus low resistance on vmem
    by cind12
    Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
    Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
    The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
    Resistance on 12V 4K ohms (Power present when on)
    Resistance on 12V PEX 4K ohms...
    12-08-2023, 09:09 AM
  • proxneo
    Recapping Sony ICF-SW55 - verifying cap values
    by proxneo
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which...
    06-21-2023, 12:38 AM
  • komadreja
    HP ProDesk 400 G4 SFF 911985-001 REV.0A blown inductors (unknow values)
    by komadreja
    Hi, a shorted mosfet((spare is on the way) and 5 smd inductors after the cpu 12v. connector totally burned.
    I have another same mobo and try to get the inductors values, but my poor LC100-A inductance meter is unable to show me nothing.
    I think the values are in nanohenries because the LC100-A can only show mH and microH.
    In the picture i replace the coils but i think is not a good idea(since i don´t know the correct values).
    The power supply are ok(tested output voltages).
    Unable to me to get that mobo schematics.
    Hope someone...
    02-04-2021, 12:21 PM
