Equivalent for BC182L
  • shaunbt123
    • Nov 2012
    • 119
    • uk
    Hi All,
    Im building a small signal booster for guitar, was wondering if there is an equivalent for the BC182L transistor?
    Cheers
  • redwire
    • Dec 2010
    • 3912
    Re: Equivalent for BC182L
    There's some story about the BC182L here. I guess it was popular in classic old guitar effects pedals, but the metal can was replaced by plastic ones.
    BC182L is 50V, B=120-500, and ECB pinout, 10 dB noise fig.
    BC547B is 45V, B=200-450, and CBE pinout, 10 dB noise fig.
    BC546B is 65V, B=200-450, and CBE pinout, 10 dB noise fig.
    BC550B is 45V, B=200-450, and CBE pinout, lowest noise 4dB
    BC549B is 30V, B=200-450, and CBE pinout, lowest noise 4dB
    Your choice depends on the power supply voltage. Note the pinouts mean you must bend the leads to match.
    • shaunbt123
      • Nov 2012
      • 119
      • uk
      Thanks for the info Redwire.
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • pickledegg
        Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
        by pickledegg
        Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
        I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
        10-02-2024, 04:54 PM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
