What should I do to convert 12v to 13v?
  • Andrewerry
    • Aug 2024
    • America
    I am working on ups for the router I have some questions:
    1. I am using lithium battery 3s whose output when full charged is 12.6 so I need 13v to charge it, I have adopter 12.22v I need to boost the voltage. Is there any way which transfer is best that work without producing too much heat I don't want to use xl6009 or any module ... just simple circuit.
    2. 12v*1.5a= 18watt == 9v*2a = 18watt. What if I give 9v 2amp to a 12v load is it work?
    • 31137
    no, you need an intelligent charger board,
    go look on ali-express for a 3cell one.
    lithium isnt like lead-acid, you cant just throw voltage at it even if you current limit it.
    you will get a very bad outcome.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8285
      First off: Welcome to Badcaps!
      A lot of stuff will "work", but what you're suggesting here isn't safe at all. Before you burn with that kind of an idea something down, go and get the correct charger on Amazon, Ali Express, etc.
      I gave up on keeping my network and router alive at home with an UPS. As soon my power goes out, so does the cable internet. I can power the home with my generator, yet no get any internet at all. I use my modem and VOIP to check if power is back, so I can turn off my generator.
        • Jul 2011
        • 6057
        Where I live I have the opposite problem when I loose power the internet is up and running but when I loose internet I still have power most of the time and this how they the power structure and these transfer switch to go from one feeder lines to another feeder lines and it not uncommon for them to trip and go back and forth between the two feeder lines and then leave the hole area with no power until the system is reset again
          • Jul 2011
          • 6057
          Yes there is a simple circuit that you can buy it is BMS protection board it comes in several different types one type is a BMS protection board that has a balancing function which is the best type and one type that does not but most cases are cheaper in cost but unless you use matched milliampere hour battery you will not have the most reliable running time unless you use a balancing BMS protection board which cost more but you still have to match milliamperes hour you can not just use new battery cells and use them you need to charge them and then load test until they are discharge to the minimum cell voltage according to the data sheet
          Your best bet is to buy a 12 volt battery pack that is professional made and hope for the best outcome unless you have the right equipment to test battery cells use the right type of BMS protection board that is the best option for what you want to do
          • Andrewerry
            • Aug 2024
            • America
            Thank you for all you replies, and I have made adjustments.☺
              • Jul 2011
              • 6057
              I would be very interested in what you come up with for this project that you are interested in doing
              Here is a video that you could use for making your own
              https://www.youtube.com/watch?app=desktop&v=H4n7TX6zcz4
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • double_DD
                Why does my ISP router hate my "homemade" power supply??
                by double_DD
                It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                07-12-2025, 03:09 AM
                HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                09-06-2024, 11:17 AM
              • shadow666
                Router Xiaomi M4A Gigabit
                by shadow666
                hello
                i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                Mi Router 4A Gigabit Edition
                ROM CHIP is 16 MB
                i attached picture of motherboard​...
                11-30-2024, 03:49 PM
              • EasyGoing1
                UPNP, "Standards" and hardware that implements it
                by EasyGoing1
                I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                So I decided to implement UPNP...
                07-16-2022, 07:12 PM
