SMD marking code - help
  • redwire
    • Dec 2010
    • 3910
    I need help identifying an SMD marking code "GGUAA" or maybe it's "66UAA", the G and 6 look the same.
    The part is a 6-pin SOT23-6 and looks like an instrumentation amp or comparator.
    Any help is appreciated.
    National Semi apparently uses "AA" as the die run code.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: SMD marking code - help
    Can we have a picture of it?
    • redwire
      • Dec 2010
      • 3910
      It's conformal coated and very small, I don't have a macro lens. The pic here is of a SOT23-6.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Yeh I know what a sot23-6 looks like - I just wanted to verify the marking.
        Not that I dont trust you just that over time we have spent hours on here looking for
        parts - having been given the wrong numbers in good faith. I know you said GG could be 66
        but if possible I like to see for myself.
        Nearest I found was something like a 6GU sot23-5 yours def has 6 legs?
        • redwire
          • Dec 2010
          • 3910
          I stared at the part for an hour with a magnifier and pretty sure it's "C6UAA" marking in a 6-pin package. An op-amp I think. Very hard to see difference between G/6/C with bubbly conformal coating
          I ended up here: SMD marking database but the pinout does not match the AD7278 (C5U)
          Thanks for any digging
            https://cdn.badcaps-static.com/pdfs/...776967a551.pdf
            Trace out pin 6 (Vs+) to see if it is connected to the + of the power supply, and see if pin 2 (Vs-) is connected to the Negative if isi an OPAMP.
            What kind of board this part is on?
            • redwire
              • Dec 2010
              • 3910
              The part is on a board for furnace flame (ion) detection. I guess it's a CMOS comparator or op-amp, but 4 layer PCB and I can't follow all traces.
              Pin 1 - goes to flame rod through 3.2meg resistor
              Pin 2 - GND
              Pin 3 - goes to 20k resistor to pin 2
              Pin 4 - GND
              Pin 5 - +5V
              Pin 6 - goes to small capacitor
                Well those pins connections as you posted does not have typical pin out for the typical OPAMP in SOT23-6.
                • Elysarian
                  • Mar 2013
                  • 200
                  A quick trawl of the internet has turned up a possible candidate...
                  The device (extrapolating from your pin-out descriptions and what it's used in) could be an ADC?
                  I found this datasheet via a Russian website referencing the C6U part of your description:
                  https://cdn.badcaps-static.com/pdfs/...580de81d85.pdf
                  I am, of course, guessing here
                  • redwire
                    • Dec 2010
                    • 3910
                    Re: SMD marking code - SOLVED
                    It is a Vishay high-voltage SPST CMOS switch DG448
                    Best SMD marking code database I found is this Russian site tomsk.ru A bit slow and not always up... but it beats Google. Thanks for everyone's help
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4977
                      • New Zealand
                      Ooh, that's a good one. Haven't seen that site before!
                      -David VanHorn
