Roland Fantom XR. Help with LCD screen pinouts
  • maleksa
    • Jul 2017
    • 50
    • Malaysia
    The LCD screen on my Roland Fantom XR rack synthesizer has gone blank. I managed to get the schematics for the connection to the LCD.
    The standard LCD has D0 to D7 pinouts (in addition to the normal VDD, VSS, CS, RES, RW, EN etc).
    Can someone help me to identify what V1 to VR is for? Also how does VR work?
    Any help is truly much appreciated.
    • 31095
    can you see what the chip(s) are on the display or are they just blobs of resin?
    it looks like a hitachi standard interface but with a lor of the voltage bits off the display board.
    read this datasheet to learn a lot about how they work
    • truclacicr
      • Apr 2019
      • 327
      • australia
      See https://www.hpinfotech.ro/SED1530.pdf
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
