Need help to identify IC
  • bigboots
    • Mar 2019
    • 43
    Not sure if this is the correct place. I need to identify This IC id anyone could help please.
    Kind Regards.
  • truclacicr
    • Apr 2019
    • 352
    • australia
    http://markingcodes.com/search/c/daas
    DAAS = MCP4151-104E/MF DFN3x3-8 SPI Single Volatile Memory 8-bit Potentiometer
    https://www.alibaba.com/product-deta...494452279.html (photo)
    http://ww1.microchip.com/downloads/e...doc/22060b.pdf (datasheet)
    • bigboots
      • Mar 2019
      • 43
      Thank you so much.
        • Jul 2011
        • 6070
        Kind Regards.
        What device is part going to be used in
        • bigboots
          • Mar 2019
          • 43
          It is for a Svod4 I ordered it over 2 month ago. They kept saying it will be posted at end of the week this went on till I asked for a refund .It did turn up and after i plugged it in and did not work. When I contacted them they did some tests and told me to open it up.When I did it had a melted ic the one in picture. I replaced it and still not working. Contacted then and now they just ignoring my messages. Asked for a replacement and they told me it's my fault. All I did was plug in the usb port and install the drivers. I have other programmers so I know how they work. Now left out of pocket so got to try to fix it. They are just ripping people off I would avoid if I knew that before. I am in the process of reading the MCU to get the info from it to reprogram a new one if I need to replace that also.
          • lotas
            • Jan 2016
            • 4818
            • Russia
            Read access will most likely be 100% blocked for the MCU; there will be protection against reading the firmware (security against cloning...).
              • Jul 2011
              • 6070
              I seriously doubt that you will be able to read the MCU because a lot of them are locked from being downloaded unless you have what call a token or something similar to that
              • bigboots
                • Mar 2019
                • 43
                Yeah mainly do electronics on cars ie MCU reading from vw clocks ecu's etc. As I am auto electrician have access to lots of programmers. We have to crack the mcu so we can gain access to the clocks. Sure it's no different.
                • truclacicr
                  • Apr 2019
                  • 352
                  • australia
                  Can you show us a photo of the whole PCB?
                  • thesame
                    DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                    by thesame
                    Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                    The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                    02-27-2024, 04:31 AM
                  • silver60618
                    Lenovo Legion 7 - Help Identify IC
                    by silver60618
                    Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                    I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                    Any help would be appreciated...
                    07-02-2025, 12:16 PM
                  • chth96
                    How can I identify varistor which have been blew up?
                    by chth96
                    I mistakely pluged 100v japanese retro game console to 220v outlet.
                    So It seems that glass fuse and varistor have been blew up.
                    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                    Is there any way to identify varistor type in my sega saturn PSU?
                    Any reply would be appreciated.
                    EDIT:
                    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                    11-26-2023, 08:52 AM
                  • freakorio
                    Need Help To Identify Component on Ymain LJ41-05120A
                    by freakorio
                    Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                    05-21-2024, 02:32 AM
                  • baiceanu_stefan
                    nm-f251 Schematic, boardview or help identify componente
                    by baiceanu_stefan
                    Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                    04-24-2024, 12:49 AM
