Preemptively Recap Motherboard?
    • 31281
    Re: Preemptively Recap Motherboard?
    Originally posted by diif
    I've been looking at the ss-02 for desoldering, i like the idea of the silicone at the end to get really close to the job.
    http://www.amazon.co.uk/innovative-s...ds=desoldering
    just put some H30X25 hellerman sleeve on the end of any pump.
      • 31281
      looks familiar!
      http://www.dx.com/p/lodestar-l304017...-yellow-284773
      this is the one sold by weller:
      http://www.dx.com/p/pro-skit-8pk-366...k-green-192877
      and this is a variant with better grip:
      http://www.dx.com/p/wlxy-ll-101-deso...k-green-258505
      • Uniballer
        • Jul 2013
        • 334
        The patents on the original Edsyn Soldapullt DS017 expired quite a while ago. So the new clones might be every bit as good. But I don't like the designs that continue half the tube to provide plunger protection. I have to keep shifting my grip on those to be able to work the plunger with my thumb. With the Soldapullt DS017 configuration you keep your thumb on the trigger button while you flip the pump around and press it against the bench (or your chest) to get ready for the next joint.
        • diif
          • Feb 2014
          • 6978
          • England
          Thanks for that tip.
          I think i'll get some next time i place an order.
          • Uniballer
            • Jul 2013
            • 334
            My impressions of a new GY-059 desoldering pump:
            The GY-059 looks very similar to an Edsyn Soldapullt DS017. I would say that it was intended to look identical, but there are a few small but noticeable differences if you are looking for them. The plastic is a darker blue, and some parts have slightly different corners, or rounding. Barrel parts will not quite interchange with those from an Edsyn DS017; the locking tabs are a different size. I could not push out the tip from the GY-059 without removing the end cap, despite the pictorial instructions indicating this method (the cocking piston appears to be a little too short). The tip appears to interchange with an Edsyn SRT12, but it is not built exactly the same. The lettering "NO SOLVENTS OR HEAT" and "COVERED BY U.S. AND FOREIGN PATENTS & PENDING APPLICATIONS" on the side of the barrel are in a slightly different font.
            Suction appears to be excellent, both by the thumb test and in actual use. The release is smooth enough that the tip does not hop around. The tip did not melt or deform when I contacted it for a short time with a Hakko FX-888D with a 3.2mm chisel tip set to 350 C. I can't say anything about long-term reliability, but while new I found the operation of this tool to be essentially indistinguishable from an original Edsyn Soldapullt DS017.
            • Uniballer
              • Jul 2013
              • 334
              It seems that the rod that cleans out the tip might be a little smaller on the GY-059, and the tip I.D. is definitely a little bigger. In any case there is a bigger gap between the inside of the tip and the cleanout rod. I haven't seen any ill effects from this yet.
              • mockingbird
                • Dec 2008
                • 5488
                #27
                Excellent, well-worded review Uniballer. I've been considering purchasing one of the knock-offs for some time now. By the way, the tips are made of teflon, and I've seen Chinese replacements available inexpensively.
                  • 31281
                  teflon or not, they will melt.
                  put some hellerman on the end.
                  • mockingbird
                    • Dec 2008
                    • 5488
                    #29
                    Teflon has a maximum temperature of 300C... The tubing you're recommending has a maximum temperature of 95C according to the datasheet. How exactly will it prevent the tip from melting?
                      • 31281
                      the hellerman sleeve is used slightly overhanging the end of the tip by about 3-4mm
                      it creates a seal to make the pump work over 100% better than before.
                      yes, hellerman sleeve will burn - very slowly.
                      first it will harden slightly, then go brown, then crack.
                      it takes hundreds of desoldering uses for that to happen.
                      and you get the sleeves in a bag of 100 or more and cut them in 2.
                      so it's a reasonable "consumable item" to use.
                      • mockingbird
                        • Dec 2008
                        • 5488
                        #31
                        Thank you, that's a very useful bit of information.
                          ASUS P5GC-MX motherboard recap
                          by momaka
                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                          So here is what the motherboard looked like with its original caps:
                          CPU VRM area up close…...
                          01-27-2021, 11:59 PM
                        • varunviolin007
                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                          by varunviolin007
                          Hi guys,
                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                          Looking for someone experienced with older PC boards who uses...
                          07-29-2025, 11:53 PM
                        • glovecaps
                          by glovecaps
                          11-25-2024, 04:23 PM
                        • Docus
                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                          by Docus
                          Hi everyone 😀,
                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                          06-10-2025, 04:24 PM
                        • Archimedes
                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                          by Archimedes
                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                          Fans are spinning. Blindly could install windows11 and got the device manager...
                          07-30-2024, 05:14 PM
