USB-C Connector Identify ?
This topic has been answered.
  • JamieAFM
    • 11
    Would appreciate any assistance in finding a replacement compatible USB-C connector for this.
    It was from a Dell Latitude 3320. Code on the connector is; 13XHK.
    I'm struggling to locate a replacement with the same footprint.
    Thanks. (Sorry if this is posted in the wrong section)
  • Answer selected by JamieAFM at 03-12-2024, 06:30 AM.
    petehall347
    • Jan 2015
    • 4448
    https://www.amazon.co.uk/Gintai-Thin.../dp/B0CHMK4HC7
    • petehall347
      • Jan 2015
      • 4448
      • JamieAFM
        • 11
        Thanks for your help, worked a treat!
        • petehall347
          • Jan 2015
          • 4448
          cool
          • drscoot
            usbc connector replacement on mobile
            by drscoot
            I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
            The battery is still charging (red led), but no power on.
            I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
            07-13-2025, 02:37 PM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • reformatt
            LCD Connector identify or source
            by reformatt
            Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
            I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
            03-25-2024, 08:29 PM
          • diamon
            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
            by diamon
            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
            Pictures of these boards:
            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
            Dell...
            02-28-2024, 12:51 PM
