Why doesn't any manufacturer create a multimeter that measures current in the same way as voltage?
  • cap__
    • Oct 2023
    • 13
    "Current is measured by inserting a measuring device into the circuit to measure the flowing current. Voltage is typically measured in a circuit in parallel. Why isn't the current calculated from the voltage?"
    • 31304
    it doesnt work that way,
    you can only read current by either putting a resistance inline and reading the voltage on both sides,
    then calculate current from the loss,
    or use a magnetic sensor to read the EM field radiating from the cable/ pcb track
    • harp
      • Jun 2022
      • 648
      • Planet Earth
      I dont quite understand question due to impedance in specific measurement, but I think that dmm actualy just do what you are write about, calculate current from voltage drop over the internal shunt resistor. DMM in current mode is just frontend interface to present you current on easy way.
      My friend in early days are measuring current of mains socket... it was just a nice analog multimeter...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Current is defined as the rate of electrons going through a point, so you have to get in between to know what's going on.
        Technically if you know the voltage across two points and the resistance, you can compute current. The problem is that the resistance between the nodes tends to be unknown and may even change. Without it known and stable, there's no way to know current through two points (plus it may "leak" to another node).
        Best you can do is using a clamp meter if you can't split the node.
          • Jul 2011
          • 6070
          Very well said and right to the point
            Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
            I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
            https://www.ebay.com/itm/116497313155?var=416785404161
            Here are some of the description from the eBay seller
            The main parameters:
            1. Product name: High-power non-isolated DC boost module power supply.
            2. Product model: 100A2000W.
            3. Input voltage: DC12V-60V.
            4. Input current: 100A (maximum)....
            05-18-2025, 09:45 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
            Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
            The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
            The bq24745 features dynamic power management...
            10-23-2024, 02:50 AM
            How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
            I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
            I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
            what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
            I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
            05-11-2025, 05:22 PM
