What is this component on our boot dryer?
  • Jackching
    • May 2017
    • 127
    Can anyone tell me what this component is with the green end? It is hooked to what looks like a bunch of coils on our boot dryer/glove dryer. The device doesnt seem to heat boots anymore. The fan still spins. The coils seem to get warm but should they get red hot? How do i test this component and how do i find out the value of it?
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    looks like a thermal fuse . what is written on it ?
    • harp
      • Jun 2022
      • 645
      • Planet Earth
      1. This is thermal fuse, and breaking temperature value is labeled on him... may be say 150 deg celisius or so, and when ambient temperature reach this point it break the circuit for safety protection. You can measure it if is still conducting, about 0 ohm if it is ok, else is bad.
      For heating boot imho, the spirals should not be red hot, not even close to that temperature, because heat excess can damage boot...
      I make this device from regulary fan hair dryier without any heater engageing, and work very well.
      https://m.youtube.com/watch?v=347W92_gxqA
      • Jackching
        • May 2017
        • 127
        Originally posted by harp
        This is a simple device to make.
        Anyway, after the device is on for a couple of minutes, it seems to produce sufficient heat. We are starting to believe the fan is not spinning fast enough now. She said normally the air is blowing out more where the boots go. Can a fan have reduced speed? There are no noises or anything coming from it and it seems to spin freely.
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • Luke Anders
          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
          by Luke Anders
          A few details about the laptop itself:
          Name: Lenovo Legion 5
          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
          BIOS Version: GKCN60WW
          EC Version: GKEC65WW
          Serial Number: PF39AQ7Z
          Board Model: NM-D562 Rev 3.0
          RAM: 16GB Installed, DDR4 (brand new)
          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
          I bought this laptop recently from eBay as a faulty device....
          10-12-2024, 05:13 AM
        • hinisa
          Xiaomi router freezes at boot after re-capping
          by hinisa
          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
          07-08-2023, 05:58 AM
        • Eaglecrest
          Whirlpool dryer control board
          by Eaglecrest
          I have a Whirlpool dryer that runs for a while then stops with a blinking timer screen. The dryer can't be reset by hitting any input and if you pull the plug and plug it back in it also won't respond. Light is on in the drum when you open the door, but no other sign of life. If I leave it unplugged for a period of time, which is multiple days, it runs again. May be able to get a load done, but now seems to be less than full load before it errors out.
          Since unplugging will get it to work, I am assuming that there is an error condition that is causing the onboard processor to shut...
          11-05-2025, 07:09 PM
        • NolesFan
          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
          by NolesFan
          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
          10-24-2024, 06:36 PM
