Help identifying component Wanscam Cam
  • marce002
    • May 2018
    • 316
    • Argentine
    Hi powered with 12v and should be 5v smoked and this 3 leg component is shorted then removed and short is gonne but need help to replace alternative (to G8 ss6)
    thanks a lot!!
    product: 5v wanscam ip cam ws00036
    damage: connected to 12v and someked
    more damage seen at: audio procesor chip sgm4890 removed too.
    Marcelo J
  • truclacicr
    • Apr 2019
    • 299
    • australia
    I suspect that it's a voltage detector or PSU supervisor.
    http://markingcodes.com/search/c/g8
    http://markingcodes.com/search/c/g8-
    G8 (or G8-) is a RT9808-42CX detector in an SOT-89 package, but RT9808 also comes in an SOT-23 package.
    I suspect that you have a 4.2V RT9808-42CV detector.
    https://pdf.dzsc.com/T98/RT9808.pdf
    This is a 2.2V detector:
    https://www.ebay.com/itm/195480602478
    ... and 2.5V:
    https://www.ebay.com/itm/404004476736
    • marce002
      • May 2018
      • 316
      • Argentine
      thanks a lot truclacicr !!
      Marcelo J
      • lotas
        • Jan 2016
        • 4555
        • Russia
        G8- xxx - RT9166-28PVL (Ultra-Fast Transient Response LDO Regulator).
        • Kazik
          Asus UX7602Z Liquid Damage - schematics or help with components identifying required
          by Kazik
          Hi, I received a Liquid Damaged Asus UX7602Z for repair. I've cleaned the motherboard and found couple of damaged components. Two of them (near the battery connector) I can't identify. One is a resistor of unknow value, and the other one is probably a transistor. Laptop won't charge the battery without them. Please see the pictures and help with components identifying. I couldn't find any schematics or boardview for this laptop.
          Laptop model: Asus UX7602Z
          Motherboard: UX7602ZM, R2.1
          Can you please help?
          Thank you....
          08-01-2024, 06:26 PM
        • Joel Ohana
          Lenovo IdeaPad 3 15IAU7 that suffered water damage
          by Joel Ohana
          I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
          Symptoms:
          • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
          • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
          What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
          03-06-2025, 11:25 AM
        • azozexd
          Need help hp 725 g3 liquid damage
          by azozexd
          Hello freind i have hp elitebook 725 g3 White liquide damage
          after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
          could some one tell me the value of this resistor
          Thank you...
          12-15-2024, 06:01 PM
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • rtstorm
          HP EliteBook 840 G8 water damage - identify component
          by rtstorm
          Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
          SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
          Here is schematics + boardview...
          09-18-2024, 05:36 PM
