Asus UX7602Z Liquid Damage - schematics or help with components identifying required
  • Kazik
    • Oct 2016
    • 53
    Hi, I received a Liquid Damaged Asus UX7602Z for repair. I've cleaned the motherboard and found couple of damaged components. Two of them (near the battery connector) I can't identify. One is a resistor of unknow value, and the other one is probably a transistor. Laptop won't charge the battery without them. Please see the pictures and help with components identifying. I couldn't find any schematics or boardview for this laptop.
    Laptop model: Asus UX7602Z
    Motherboard: UX7602ZM, R2.1
    Can you please help?
    Thank you.
  • csberti03
    Asus ROG G513QC liquid damage
    by csberti03
    Hi!
    I have an Asus ROG with some liquid.
    I already replaced most of the damaged components.
    But there are some resistors that have OL resistance but i don't have the exact value to replace them.
    In boardview it carries a signal called VRAM_DGPU_TON.
    First is 2.2 Ohm 5% (R67218)
    Second is 499K Ohm 1% (R67217)
    also R6016 Measures 210k instead of the 130k in boardview.
    It's part of AC_SHORT_DETECTION circuit.
    Should I replace that?
    I have 1 ohm, 3.3 ohm, 100k, 470K resistors.
    Is it OK to use those...
    12-18-2024, 12:28 PM
  • bogosort
    Asus FX505GT, voltage reading after minor liquid damage
    by bogosort
    TLDR:
    Are these voltage readings normal? What should I do next?
    Long story:
    I have an Asus FX505GT laptop that received a small amount of liquid.
    Since then, installing the Intel GPU drivers causes a black screen, then an infinite Windows loading until I uninstall the driver using safe mode.
    The laptop still works when using the default Microsoft display driver, but the video memory shows as unknown in hwinfo.
    Installing the GTX 1650 max-q drivers works, but there does not seem to be any acceleration....
    12-07-2022, 02:54 PM
  • av4x
    Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
    by av4x
    Good morning, everyone!
    I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
    First up is a Fujitsu Lifebook U7511.
    It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
    Model: Fujitsu Lifebook U7511
    CPU: Intel Core i5-1135G7
    GPU: Intel Iris Xe Graphics
    RAM: 16GB DDR4 - 3,200 MHz
    PCB manufacturer: ASKPCB?
    PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
    Damage: Liquid damage
    The liquid probably...
    11-01-2025, 03:09 AM
  • rounin
    MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
    by rounin
    Device Information
    • Model: MacBook Pro 14” M1 Pro (A2442)
    • Logic board number: 820-02443-05
    Original Issue
    The device suffered liquid damage, causing a short circuit on the logic board.
    Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
    Work Performed
    Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
    Current Status
    • When powered on, the screen shows support.apple.com/mac/restore....
    10-20-2025, 11:15 PM
  • rilley
    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
    by rilley
    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
    And the resistor L4004 is literally burned.
    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
    07-10-2024, 01:57 AM
