Help me decide which MOSFETs are suitable replacements
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Friends,
    I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
    MDD1502 (high side), 48.5A 7.8mOhm
    MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
    VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
    Here are the ones I'm currently looking at:
    Matsuki ME60N03 (high side) 50A 8.8mOhm
    Matsuki ME70N03 (low side) 70A 5.6mOhm
    Nikos P0903BDG (high side) 50A 9.8mOhm
    Nikos P0603BDG (low side) 75A 6.5mOhm
    which I already have a few in stock, taken from old gen mobos with dead PCH.
    Do you think they will work fine as replacements?
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Oh well, I guess I will just pick either pair and try it myself. Hopefully they won't blow up again and take out the processor.
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      Just a quick update. IT DIDN'T WORK AT ALL. No switching was happening. A new PWM controller IC, new mosfets, and instead of getting a 3.3V enable signal, I got 7V which doesn't make any sense at all considering it is pulled high to 3.3V BUS!
      Either I have a DOA PWM controller, or I have killed a component that sets it up to work when I removed the old controller with my hot air station.
      So I removed it and also the mosfets (again!), the enable signal returns to 3V.
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        MOSFETs replacement work fine. I had 7V EN on the PWM IC because the center ground/thermal pad was not making a proper contact with the board. Re-soldering the IC for the 2nd time fixed the issue. Power rail came back to life.
        The MOSFETs that I ended up using were the Matsuki ME60N03 + ME70N03 pair.
        Device got sold a couple of days ago 😬
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
        • DrDos
          kenwood kr-6030 Mosfets?????
          by DrDos
          Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
          09-20-2025, 04:42 PM
          by momaka
          03-12-2025, 03:42 PM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
        • BlackScreen_22
          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
          by BlackScreen_22
          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
          I had no problems connecting mosfets and capacitors,...
          08-27-2024, 12:46 PM
