1.5 amps vs. 3 amps DJL vs. DJA
  • apetay
    • Dec 2013
    • 24
    sorry I'm a nooby, and I can't seem to find a straight answer. If I have a bulb socket that is rated 120v 150W 3amps, and there's another bulb with the same form factor, only difference is it's rated at 1.5 amps, can I use it as a replacement?
    The bulb place says it's a "possible" match, and I don't mind if it is more dim, I just don't want to fry my projector. If I blow the bulb, at least I tried. It's an old Anscovision 88, but the mechanical is still good.
    Swap in DJL for DJA
    3 repairs under my belt, 3 repairs in progress
  • redwire
    • Dec 2010
    • 3912
    Re: 1.5 amps vs. 3 amps DJL vs. DJA
    The two lamps have different focal distances, a 1/2" difference to the filmgate, so the substitute lamp would give less light. I don't know the Ancovision 88 specs. Maybe a DFG?
    DJA datasheet DJL datasheet Source: Don's Bulbs
    The lamp socket rating is limited by two things- its heat rating for the socket and current rating for the connecting pins. Do you mean substitute a 3A (360W@120V) socket for a 1.5A socket (180W@120v)? That's okay.
    Socket ratings depend on if the socket is ceramic or bakelight, and if there is a cooling fan, inrush current blah blah.
    Don't upsize (double) the lamp wattage.... things will melt...
    • apetay
      • Dec 2013
      • 24
      Thanks redwire! This was the kinda answer I was looking for. DJA is the one rated for 3 amps that I know my projector can use, however I found some DJL's rated at 1.5 amps, for a very good price. Most of the "info" I saw said that the two had the same W and V ratings, and it was only the amps that were different. I think this is just typical internet disinformation, or I just wasn't paying close enough attention. What's this "inrush current" you speak of? The Ansco 88 does have a cooling fan, btw, and the badge clearly states DFP is a usable bulb as well as DJA.
      • LLLlllou
        • May 2011
        • 201
        Not "disinformation", but a flat out lie that defies the laws of physics.
        Wattage "W" is calculated by Voltage "V" times Current "A"
        120V x 3.0A = 360 Watts
        120V x 1.5A = 180 Watts
        Filament light bulbs have a much lower resistance when cold then they do when they are hot, so they pull allot more current at turn on then they do after they reach their normal operating temp. The current pulled by a cold bulb is the "inrush current". it only lasts a few milliseconds, but can be many times the normal current.
        • apetay
          • Dec 2013
          • 24
          More real answers. Geez I love this forum!!!!
          • mockingbird
            • Dec 2008
            • 5488
            Is this by any chance for a Super 8 projector??? Are you digitizing reels?
            • LLLlllou
              • May 2011
              • 201
              Mind you, that's not to say that every light that uses 360 watts puts out twice the optical output as every 180 Watt light. Comparing apples to apples, one tungsten filament bulb is going to be extremely similar to the next. Apples to oranges, Florescent bulbs put out about 2-3 times as much light per watt, and LEDs can double that again. If we ever find a way to turn electrons into photons with 100% efficiency, one watt would probably vaporize your retinas.
              • redwire
                • Dec 2010
                • 3912
                These projector lamps are pushed pretty hard to get their 3200K color temp. CRI. They have only a 15hr life rating and I'm pretty sure they aren't halogen, as the halogen lamp (commercial) patent is 1959, took a while to make "hard" glass. I think 8mm projectors were popular in the late 1960's.
                Modern DLP projector lamps are 1,000-2,000 hour life rated but expensive. It might be worth hacking one into an old projector?
                Source: "Revolution in Lamps: A Chronicle of 50 Years of Progress" ISBN 0-88173-378-4
                • apetay
                  • Dec 2013
                  • 24
                  Yes indeed on both accounts- I'm digitizing some early 70's home movies for my Mom's birthday.
                  This project's been on the back-burner for a long long time. I've considered trying to wire in some LED's, but 15 hours of standard bulb life would likely get me by...
                  • apetay
                    • Dec 2013
                    • 24
                    If it's one thing I don't need help with vaporized retinas! I'm sitting at 20/200 unassisted.
                    • repair-it
                      TOSHIBA DLP 52HM95 How to reset timer module on bulb
                      by repair-it
                      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                      10-11-2023, 07:18 PM
                    • ezenia
                      LUMIMAN Smart Bulb IC ID?
                      by ezenia
                      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                      04-28-2025, 05:56 PM
                      Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                      09-06-2024, 06:11 AM
                    • Stephen
                      A2991 Logic Board issue, 20volts 0 amps help!
                      by Stephen
                      Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                      09-10-2025, 03:16 PM
                    • Stephen
                      A2991 logic board issue, 20volts 0 amps help!
                      by Stephen
                      09-10-2025, 03:15 PM
