18n50 or 24N50
  • dcapper
    • Dec 2013
    • 496
    18n50 or 24N50
    I have a tv with an 18N50 that blew. I have access to a 24N50. Could I use the 24N50 instead? The characteristics look the same but just the 24 amp drain current and the rds is is a little lower.
  • LLLlllou
    • May 2011
    • 201
    Re: 18n50 or 24N50
    Higher drain current is good, lower RDS is better. Higher input C is something to consider. If the replacement MOSFET's input capacitance is too high, and the driver circuit is weak, the MOSFET won't turn on completely. Not turning on completely means high RDS, which means high heat, which means . . .
    That being said, it's HIGHLY unlikely that the difference between two like parts from the same series would be a problem, you could probably put two or more in parallel and still not have any problem.
    • dcapper
      • Dec 2013
      • 496
      Re: 18n50 or 24N50
      Thanks. I thought of that but for what it's worth, I'll just order new ones from digikey. Then there will be no doubt.
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
      • hikomalek
        SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
        by hikomalek
        Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
        When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
        Transformer:
        |Info| Primary | Aux | AB | CD|
        |Ratio|1|25|40|12|
        |Voltage AC|230V|9.2V|5.8V|19V|
        |Voltage DC (*1.41)|230V|13V|8.1V|27V|
        I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
        09-19-2025, 03:30 AM
      • mo000
        IS THAT TRUE? dynabook no power .
        by mo000
        hi
        i have dynabokk c50-g-102 i5 10th gen
        IP3_CN16S_MB_V20_202001229B
        the laptop die no power no charging led no nothing
        i can't find schematic or boardview
        no short on motherboard
        19v stop on source of pq2 drain=0v
        on the gate of pq1 and pq2 =18.5v qnd source 19v but pq1 and pq2 qre pchannel which is means the source voltage should be lower
        what i know is gate of pq1 and pq2 controlled by charger ic here is bq24780s but vcc of bq=0v which means ther is somthing else controlling mosfet gate
        i think kbc IT8987E is controll the gates of both...
        08-25-2025, 07:57 AM
      • jordanaudio1
        Samsung TV UN60KU6270F power supply
        by jordanaudio1
        Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
        My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
        07-07-2025, 07:38 PM
      • h0m3w0rk
        Repairing a Music Store Professional GO! SUB 18A
        by h0m3w0rk
        I'm working on repairing a Music Store Professional GO! SUB 18A bass subwoofer, and I need some help troubleshooting an issue with the power amplifier board. The board uses an IR2153 driver and originally had two SLW20N50C MOSFETs. Unfortunately, these MOSFETs burned out. I replaced them with two TK20J60W MOSFETs; however, these also failed almost immediately.
        Here are some details:
        • SLW20N50C (original):
          • Rated for 500 V
          • Typical RDS(ON): 0.21 Ω
          • Continuous Drain Current: 20 A at 25°C (13 A at 100°C)
          • Pulsed Drain Current: 80 A
          • Avalanche
        02-27-2025, 07:42 AM
