trying to find data sheet for the following voltage regulator
  • Dolph181
    • Oct 2012
    I've looked for the logo, but can't find out who the manufacturer is of this voltage regulator. Help finding the data sheet or the manufacturer?
    Thanks!
    -Kyle
  • Majestyk
    • Nov 2013
    • 96
    Re: trying to find data sheet for the following voltage regulator
    ST made the KD1084 a 5A low drop voltage regulator, available in DPAK and D2PAK package also.
    There are fixed versions for 1.8, 2.5, 3.3 and 5V output voltage.
    You can find datasheets at alldatasheets.com
      What voltage do you get on all 3 pins? It comes in as Adj. or Fixed regulator.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        Is that the same as Linear Technology's LT1084? The "0849" is the datecode, and STMicro's date & lot code system is not as simple as what is on that part (you need the "decoder ring" from STMicro to decypher their date/lot code info).
        PeteS in CA
          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
          Based on Intersil's Robust Ripple Regulator...
          11-05-2024, 03:24 PM
        • Prott
          PCB Layer to layer short on a low voltage power plane - how to find it?
          by Prott
          Hello!
          Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
          Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
          Silly idea no. 1: Can I...
          08-01-2024, 12:09 PM
        • artvandalai
          Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
          by artvandalai
          This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
          The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
          11-05-2024, 07:38 AM
        • shakib200
          Ram regulator misbehaving DDR3 VTT voltage Tps 51216
          by shakib200
          The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
          Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
          03-16-2024, 11:33 AM
        • Long AMD
          Acer AL1916W - Two seconds to black - Voltage regulator problem?
          by Long AMD
          Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
          I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
          The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
          09-13-2020, 05:59 PM
