Driving The Backlight: CCFLs Or LEDs?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Bob Arnold, Joe Barnett, Tom Novitsky | ED Online ID #14814 | February 15, 2007
    The typical LCD backlight can be one or more cold cathode fluorescent lamps (CCFLs) or an array of light-emitting diodes (LEDs). An example of each is shown in Figure 1. The quality of the backlight image depends heavily on the backlight driver. In this article, we will discuss the considerations one can make for CCFLs and LEDs, as well as how to power both kinds of backlight.
    GENERAL CCFL CONSIDERATIONS
    CCFL backlights are the most common backlight technology and are used in displays ranging from 5.7 to 23 in. or more diagonal. They can have from one to 24 or more lamps mounted along the edge of the LCD or spaced uniformly over the entire back of the display.
    Typically, brightness is controlled by modulating the CCFL current or lamp duty cycle. The basic driver is a dc-to-ac inverter powered by 5 to 48 V dc.
    GENERAL LED CONSIDERATIONS
    LEDs are already used in a wide range of smaller displays. For larger displays, because of their higher power consumption and, in some cases, their mercury content, CCFL backlights are beginning to be replaced by LED backlighting. LEDs may be arranged along the edges of the LCD or as a matrix over the back of the LCD assembly. The LED devices may be arranged in series or parallel. Either configuration will provide uniform LCD lighting. The LED strings can be arranged in parallel using a series resistor in each string to provide string-to-string current balancing as well as lighting redundancy.
    PeteS in CA
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Driving The Backlight: CCFLs Or LEDs?
    when is leds in computer lcd coming? i have only seen them in one $4000 Samsung tv.....
    • stretch0069
      Screwed Up Super Moderator
      • Oct 2003
      • 2662
      • oooo ess aaaaaaaaa
      I have the Samsung LED DLP HR-S5679. They don't use LEDs for backlighting though. There are three LEDs; Red, Blue, Green. They modulate their output that is then projected on the DMD which then gets reflected up on the screen. This eliminates the lamp and the color wheel. More importantly, and why I bought this one, it eliminates the damned rainbow effect that plagues traditional DLPs.
      There have been people that say its not a very bright display, but I don't see any problems with it.
      "Its all about the boom....."
      Guns kill people like spoons made Rosie O'Donnell fat.
      We now return you to your regularly scheduled drinking.
      "Fear accompanies the possibility of death.....calm shepherds its certainty"
      Originally posted by Topcat
      AWD is just training wheels for RWD.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        the one i was talking about is LE40M91B
        pity no good info on the net........
        • stretch0069
          • Oct 2003
          • 2662
          whoops.....my bad.
          I didn't even know it existed. I haven't seen anything here. Then again, its only 40".
          i tried to see if there was any info, but no good info...in English. Oh well.
          • pni
            Backlight panel diffuser melt by backlight leds broken
            by pni
            Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
            10-12-2025, 12:08 AM
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • hollox123
            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
            by hollox123
            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
            1. Laptop keyboard doesn't work
            2. The backlight on the laptop keyboard doesn't work
            3. The x2 side LEDs (red) on the laptop don't work
            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
            But I am strongly aiming that it is somehow a BIOS-related problem,...
            05-11-2025, 08:05 AM
          • signal.quest
            Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
            by signal.quest
            I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
            03-17-2024, 10:14 AM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
