MOSFET 2SK3018 advice
    I am hoping someone will be able to advise me on this mosfet. I am trouble shooting a circuit on a Panasonic plasma psu - thread here, and have noticed that i have a constant resistance of about 57ohm between the Gate and Source pins on this little fet, (Q422). I have followed the traces on both the pcb and the schematic, and have determined that the resistance is within the fet itself.
    Here is a link to the data sheet for the Mosfet, it's the SOT-323 package.
    http://www.sztuofeng.com/pdf/2SK3018.pdf
    I know nothing about mosfets, but i have noticed that this is the only one i have come across in the circuit where i am getting a constant resistance reading between the gate and source.
    Is this a normal reading?, or could i have a problem with this fet?
    Any advice will be appreciated. Thanks.
    P.S, I used a multimeter for the resistance readings. The board was not powered.
    Re: MOSFET 2SK3018 advice
    if you inter change the probe of the meter is it the same reading if yes then is faulty
      make sure to romove it from the ps before testing it
        Thank you for the replies.
        Yes to both of them, whichever way round i have the probes, i still get a 57ohm resistance. I also took your advice and removed the mosfet from the board (though i was certain there was not a path between them on the board). With the part removed from the board, i still get the 57ohm between Gate and Source.
        So this fet is no good? Thank you again for the information, i feel i am making progress with the trouble shooting now.
          It has built-in Gate-Source protection Diode which may be damaged.
            Thank you budm, i have ordered a couple of replacements, luckily they are easily available. I ordered a couple in case of mishaps when fitting - never fitted one of those tiny SOT-323's before.
