Reading Resistance with Multimeter
  • General_T
    • Sep 2013
    • 36
    I am new to this and am trying some very basic projects to get some sort of understanding with electronics.
    I put a 1k ohm resistor on to a breadboard to see what the resistance would be. I assumed it would be the same as when it is just by itself.
    Tested by itself (not on the breadboard) my multimeter (fluke 179) reads 1k ohms - as I would expect. But when I place the resistor on the breadboard - all by itself with no power - the multimeter reads .2 ohms. Why does it not read 1k ohms?
    Appreciate any insight to this as I expected it to read near 1k ohm.
  • mariushm
    • May 2011
    • 3799
    Re: Reading Resistance with Multimeter
    HOW did you put it on a breadboard?
    A breadboard has all the holes in a vertical line connected together. So, if you put a resistor that way, the resistor is shorted and you're basically measuring the resistance of the probes' wires.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      put it into the breadboard in another direction, i think you "shorted" the resistor
      • General_T
        • Sep 2013
        • 36
        D'oh - if it can be done - wrong - I will do it!!
        Thanks Guys.
        (SIGH - so much to learn!!)
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • flat-earther
          Hoover FM216LI cordless vacuum refuses to charge
          by flat-earther
          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
          06-06-2025, 03:14 AM
        • DrDos
          Wierd reading on my multimeter
          by DrDos
          I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
          09-12-2025, 04:44 PM
        • harp
          high voltage high resistance marking resistor
          by harp
          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
          08-26-2024, 01:42 PM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
