Is this a capacitor?
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hello everyone. I have a Ibanez Distoration pedal that I'm working on for someone. When the battery's plugged in, it works. When it's running off a transformer, it doesn't. I've checked the jack and it works and everything. Things that should read ground read hot with the transformer but not with the battery. Almost everything reads hot with the transformer hooked up. I'm testing components and wanted to know if this was a capacitor. I've never seen anything like it before. If so, can I test it with my ESR meter and is it polarized or non-polarized? The black dot is from a marker so I have an idea of how it goes back in... Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Is this a capacitor?
    yes, its some type of plastic film capacitor. 0.022uf or 22nf.
    The J indicates its value tolerance, 5% I think.
      Pedal effect boxes use outside of the barrel plug as positive, the inner is negative.
      • Spork Schivago
        • Mar 2012
        • 4734
        Thank you BudM. Do you or anyone else have any idea where I should start looking? I know that it uses a negative-pin transformer. I used a 9v battery and cut a broken transformer cord off and hooked it up to test because I do believe the original transformer is bad for this. I'm scratching my head on this one. There's a three pin connector going to another board. Pin 3 on the schematic shows it shoulkd be VCC, pin 2 GND and pin 1 should be D15. All three read hot with a transformer hooked in, including my 9v battery with a DC jack hookup.
        • Spork Schivago
          • Mar 2012
          • 4734
          Thank you rievax_60. My ESR meter won't test them. I have to use my DMM. Are they polarized? Not 100% sure which way the first one came out.
            You have the SCH? By the way, that polyester cap will not read right with ESR meter. I doubt that it is bad and causing the problem.
            • Spork Schivago
              • Mar 2012
              • 4734
              Yup, uploading it now. Thank you.
              • Spork Schivago
                • Mar 2012
                • 4734
                Hey, R69 on the FUNCTION SW PCB 1/2 shows it should be 1Mohm. I haven't removed it to test it because it's surface mount and I have trouble with those but in circuit, it tests extremely low with my DMM. If I remember correctly, 200ohm. It's by the button that turns it on. Could that be the problem?
                  Does the wall wart read 9VDC when you plug it into the jack? I ran into some effect that just refuse to work when the DC input is less than 8.5V. What you can do is the use 9V battery to simulate the wallwart and feed it into the DC jack.
                    That section is just the Flip-Flop for toggling in and out effect.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Never heard of the word wall wart. I'm assuming you mean the wall transformer? It does read 9VDC but the amperage jumps all over the place. Hench the reason I'm using the 9V battery to simulate the transformer.
                        So when you have 9V external connected to the DC input jack, it works, right? That wall wart (or external DC power supply) should be able to handle the current draw if you get the one with the correct capacity, it should not be jumping around if it can handle the power requirement by the effect box. What is the rating of this DC power supply you are using? If the wall wart is 9V when you measure without the load it should read about 14VDC.
                        http://en.wikipedia.org/wiki/AC_adapter
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          I also pulled the diode on the main board and tested that. It tested good. There's some transistors that I tested but I don't know how to tell if they're bad. They say C1815 (but the schematics say 2SC1815). I tested five of them and all the readings from my DCA meter where the same except for something called Current Gain Hfe which read 315 on TR9, 284 on TR8, 284 on TR5, 295 on TR1, and 293 on TR2. Does that seem right?
                            If it works correctly with battery, then it is not the circuit problem, when you insert the plug into the DC jack, all it does is to switch the power from internal battery to the external power source, that is, nothing else change in the circuit. The Diode D7 connected to the DC jack is for wrong polarity protection.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              No, it only works with a 9V battery hooked up to the battery connection. When I have it hooked up threw the DC jack, the unit does not work.
                              The DC power supply that I was using was 9VDC 0.5A (500mA), which, according to the internet, should work with this unit. It says to use one of three of their transformers and never use any others. This is a generic one the guy found. It can use a 200mA, 300mA or a 500mA 9VDC power supply.
                              I think they just put the only use theirs because of the negative-pin power supply.
                                So when you use the external power supply, what DC voltage do you get across the two pin of D7, Red probe on Cathode, Black on Anode.It should show 9V when you use the internal battery and the same reading when you use the external power. D7 is connected in parallel with the power source, either the internal battery or external power source. picture of your power supply?
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  The DC voltage when using the internal battery is 8.36VDC, with my battery-to-DC-jack contraption, I get 0VDC.
                                  The way I was testing it earlier when I got voltages across everything, I had to put the black probe on the negative part of my contraptions battery. Otherwise, I would never get a reading for some reason.
                                  I messed up, didn't I? The problem has to be before that diode, right? And that diode is early in the circuitry, right? Could I try replacing that D7 1N4003 diode with a 1N4004 diode? Or do I have to use the exact same diode that's on the board?
                                  Thanks.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    Oh, when you say power supply, what do you mean? The circuitry, wall wart or my contraption?
                                      As you can see from the SCH, when you do not have the external power supply connected to DC jack J4, the Positive of battery A1 is connected to J4 pin 2 and through the switch contact of J4 pin 3, then out put to the Cathode of D7 which supply the Positive voltage to the circuit. The Negative of A battery is connected to J1 pin3, so when the Mono phone plug is inserted into the Input jack, the negative is then connected to J1 pin 1 which is connected to the circuit ground, thus complete the circuit path to supply the A1 battery to the circuit.
                                      When the DC plug is inserted, J4 pin 2 and pin 3 circuit (switch) is open, which disconnect the positive of Battery A1 from the circuit, the positive voltage from the DC plug barrel is now supplying the positive to to the circuit through J4 pin3, the center pin negative of the DC plug is connected to J4 pin1 to circuit ground complete the path for the external power supply. The rest of the circuits does change, just the power supply source is changed.
                                        Yes, the external power supply, or I call it wall wart. That D7 will conduct and crow bar (short the External power supply output) if the polarity is wrong. The Diode will destroy itself by shorting out and not letting the wrong polarity (clamp down the voltage to about 0.6v before it is damaged and shorted out), to get through to do the damage to the circuit. The unit will work without that Diode but you will not have protection. It sounds to me that your contraption does not have the correct polarity, that is why you are reading 0V on D7. IN4004 will fine for now.
                                        So basically, the positive of either the internal battery or from the external power supply (wall wart, or what ever power source you are using to plug into the DC jack) will ALWAYS connected to the Cathode of the protection DIODE D7, the negative will ALWAYS be connected to the Anode of D7, D7 is in reverse bias mode so it will not conduct. I will conduct if the polarity of the battery or the external power supply is wrong.
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
