Hello everyone. I have a Ibanez Distoration pedal that I'm working on for someone. When the battery's plugged in, it works. When it's running off a transformer, it doesn't. I've checked the jack and it works and everything. Things that should read ground read hot with the transformer but not with the battery. Almost everything reads hot with the transformer hooked up. I'm testing components and wanted to know if this was a capacitor. I've never seen anything like it before. If so, can I test it with my ESR meter and is it polarized or non-polarized? The black dot is from a marker so I have an idea of how it goes back in... Thanks.
Is this a capacitor?
Tags: None
Re: Is this a capacitor?
Pedal effect boxes use outside of the barrel plug as positive, the inner is negative.Never stop learning
Thank you BudM. Do you or anyone else have any idea where I should start looking? I know that it uses a negative-pin transformer. I used a 9v battery and cut a broken transformer cord off and hooked it up to test because I do believe the original transformer is bad for this. I'm scratching my head on this one. There's a three pin connector going to another board. Pin 3 on the schematic shows it shoulkd be VCC, pin 2 GND and pin 1 should be D15. All three read hot with a transformer hooked in, including my 9v battery with a DC jack hookup.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Thank you rievax_60. My ESR meter won't test them. I have to use my DMM. Are they polarized? Not 100% sure which way the first one came out.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
You have the SCH? By the way, that polyester cap will not read right with ESR meter. I doubt that it is bad and causing the problem.Last edited by budm; 09-09-2013, 09:28 PM.Never stop learning
Attached Files-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Hey, R69 on the FUNCTION SW PCB 1/2 shows it should be 1Mohm. I haven't removed it to test it because it's surface mount and I have trouble with those but in circuit, it tests extremely low with my DMM. If I remember correctly, 200ohm. It's by the button that turns it on. Could that be the problem?-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Does the wall wart read 9VDC when you plug it into the jack? I ran into some effect that just refuse to work when the DC input is less than 8.5V. What you can do is the use 9V battery to simulate the wallwart and feed it into the DC jack.Never stop learning
That section is just the Flip-Flop for toggling in and out effect.Never stop learning
Never heard of the word wall wart. I'm assuming you mean the wall transformer? It does read 9VDC but the amperage jumps all over the place. Hench the reason I'm using the 9V battery to simulate the transformer.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
So when you have 9V external connected to the DC input jack, it works, right? That wall wart (or external DC power supply) should be able to handle the current draw if you get the one with the correct capacity, it should not be jumping around if it can handle the power requirement by the effect box. What is the rating of this DC power supply you are using? If the wall wart is 9V when you measure without the load it should read about 14VDC.
http://en.wikipedia.org/wiki/AC_adapterLast edited by budm; 09-09-2013, 10:02 PM.Never stop learning
I also pulled the diode on the main board and tested that. It tested good. There's some transistors that I tested but I don't know how to tell if they're bad. They say C1815 (but the schematics say 2SC1815). I tested five of them and all the readings from my DCA meter where the same except for something called Current Gain Hfe which read 315 on TR9, 284 on TR8, 284 on TR5, 295 on TR1, and 293 on TR2. Does that seem right?-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
If it works correctly with battery, then it is not the circuit problem, when you insert the plug into the DC jack, all it does is to switch the power from internal battery to the external power source, that is, nothing else change in the circuit. The Diode D7 connected to the DC jack is for wrong polarity protection.Last edited by budm; 09-09-2013, 10:09 PM.Never stop learning
The DC power supply that I was using was 9VDC 0.5A (500mA), which, according to the internet, should work with this unit. It says to use one of three of their transformers and never use any others. This is a generic one the guy found. It can use a 200mA, 300mA or a 500mA 9VDC power supply.
I think they just put the only use theirs because of the negative-pin power supply.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
So when you use the external power supply, what DC voltage do you get across the two pin of D7, Red probe on Cathode, Black on Anode.It should show 9V when you use the internal battery and the same reading when you use the external power. D7 is connected in parallel with the power source, either the internal battery or external power source. picture of your power supply?Last edited by budm; 09-09-2013, 10:18 PM.Never stop learning
The way I was testing it earlier when I got voltages across everything, I had to put the black probe on the negative part of my contraptions battery. Otherwise, I would never get a reading for some reason.
I messed up, didn't I? The problem has to be before that diode, right? And that diode is early in the circuitry, right? Could I try replacing that D7 1N4003 diode with a 1N4004 diode? Or do I have to use the exact same diode that's on the board?
Thanks.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Oh, when you say power supply, what do you mean? The circuitry, wall wart or my contraption?-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
As you can see from the SCH, when you do not have the external power supply connected to DC jack J4, the Positive of battery A1 is connected to J4 pin 2 and through the switch contact of J4 pin 3, then out put to the Cathode of D7 which supply the Positive voltage to the circuit. The Negative of A battery is connected to J1 pin3, so when the Mono phone plug is inserted into the Input jack, the negative is then connected to J1 pin 1 which is connected to the circuit ground, thus complete the circuit path to supply the A1 battery to the circuit.
When the DC plug is inserted, J4 pin 2 and pin 3 circuit (switch) is open, which disconnect the positive of Battery A1 from the circuit, the positive voltage from the DC plug barrel is now supplying the positive to to the circuit through J4 pin3, the center pin negative of the DC plug is connected to J4 pin1 to circuit ground complete the path for the external power supply. The rest of the circuits does change, just the power supply source is changed.Never stop learning
Yes, the external power supply, or I call it wall wart. That D7 will conduct and crow bar (short the External power supply output) if the polarity is wrong. The Diode will destroy itself by shorting out and not letting the wrong polarity (clamp down the voltage to about 0.6v before it is damaged and shorted out), to get through to do the damage to the circuit. The unit will work without that Diode but you will not have protection. It sounds to me that your contraption does not have the correct polarity, that is why you are reading 0V on D7. IN4004 will fine for now.
So basically, the positive of either the internal battery or from the external power supply (wall wart, or what ever power source you are using to plug into the DC jack) will ALWAYS connected to the Cathode of the protection DIODE D7, the negative will ALWAYS be connected to the Anode of D7, D7 is in reverse bias mode so it will not conduct. I will conduct if the polarity of the battery or the external power supply is wrong.Last edited by budm; 09-09-2013, 11:01 PM.Never stop learning
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by CG2OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
I know that these capacitor will not last as long as nichicon capacitor...-
Channel: General Capacitor Questions & Issues
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
- Loading...
