Computer PSU 5v drop
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day, I have a Thermaltake 850 watts Toughpower power supply. I've tested it using a multimeter and I see 5v is dropping. It cannot boot my desktop pc anymore.
    Other reading such 5v, 3.3v, 12v, -12v 5vSB are ok but the 5v shows only 3v. I just want to know what electronic component usually go out when 5v is dropping? I'm thinking about a DIY method on fixing this power supply. I think its not that complicated or is it? Thanks!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Computer PSU 5v drop
    Look inside, does it have any bulging capacitors?
    Could you take some pictures also?
    Muh-soggy-knee
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      I can't seem to find any bulging capacitors. I can take some pictures, I'll post it tomorrow. It'll be difficult to remove the power supply from the case because it has a separate board on top of it. I think I need to desolder it first to remove it.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        You may have a half-shorted 5v diode. I've seen that before. Take the PSU apart and post pics, and then i'll point at things you can check.
        A working TV? How boring!
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          Good day, this is the best image I can get, would this help? Its hard to see the whole components inside because its a little congested. Maybe I can remove those 2 huge heatsinks to make the view better. I also double checked if I missed some bloated capacitors but I see none. Thanks Again.
          • pdavid
            • Jan 2011
            • 279
            • Hungary
            Interesting. I had the same problem with the same build (CWT PSH). I know the cause wasn't the capacitors. I don't remember what fixed it ultimately though. Need to track back a little in my repair logs...
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              What I have said here is confusing what I meant was 3.3v, 12v, -12v and 5vsb are ok but not the 5v. sorry for the wrong input
              Some friends told me to try and replace transistors which are attached to a heatsink that links to 5v, but I don't know which one. The best thing to do as of now is to look for datasheets regarding those transistors and see what characteristics they have. Thanks guys!
              • crystalsercpn
                • Jul 2013
                • 13
                • india
                What is the solution of this you got ? please share with me Thanks.
                • lezsimply
                  The Wanderer
                  • 645
                  • Philippines
                  what do usually fail when 5v go crazy. Its hard to remove components on this kind of power supply unlike the typical ones. I think they used a much strong lead on it. I use to remove bloated capacitor without problems but this one is kind of a tricky one.
                  @ganes
                  I haven't found any solution to this problem yet. Still waiting someone of experience on this. Hope someone will do. Let see.
                  Last edited by lezsimply; 09-18-2013, 04:56 PM. Reason: forget to answer someone question
                  • c_hegge
                    • Sep 2009
                    • 5219
                    The 5V rectifier(s) could be at fault (which is what Th3_Un1qu3 was saying). It's attached to the secondary heat sink (the one closest to the output side). I think it's the one circled (although it might be the one below it). The 12V rectifier is almost definitely the one closest to the top of the pic. If you can remove the secondary heat sink, then see which order the bundles of wires are in. The rectifiers will almost definitely be in the same order. Note that there may be two 5V rectifiers. If so, the other one will be installed on the other side of the heat sink directly opposite the circled one. If there are two of them, then replace them both.
                    • lezsimply
                      The Wanderer
                      • 645
                      • Philippines
                      Oh my bad Sorry but I didn't noticed unique's post honestly.. just read it now. I was waiting for someone to reply on my post yet I have overlooked it. Thank you very much c_hegge for mentioning it. I'll try it soon tomorrow and post some updates. Thanks again!
                      • JonathanAnon
                        • Jul 2012
                        • 457
                        • Ireland
                        Like the guys said above, it may just be something on the +5V rail ... inductor, fuse, capacitor, regulator, or fast rectification diodes... Only problem with those PC power supplies is that they are CRAMMED into such a small space.. But if you could trace back from the +5v output you may be able to get back to the rectifiers after the switch mode power transformer (i.e. and identify each of the relevant components). WITH THE POWER TURNED OFF, I would test all the components along that +5V line, starting with the rectification diodes.
                        Have you tried the same PSU with another board just to be sure that it's not shutting down because of a problem with the motherboard? If it was me, I would test it with another board before starting the troubleshooting process.
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          maybe just a bulged caps. use ESR meter to found it if that is no sign about bulged caps. also with off board test can give a exact result.
                          "There is no shortcut to be successful. No pain, no gain."
                          Best Regards
                          Rudi
                          Thank You
                          • lezsimply
                            The Wanderer
                            • 645
                            • Philippines
                            Until now I cannot seem to find a way to remove the secondary heatsink without breaking it as it is really bound to the board. The leads used in this power supply is hard to remove. Already used 60 watts soldering iron. I think its not my soldering skill because I can remove any capacitor on a desktop motherboard. no bulging capacitor found. I think I'll be trying a 90 watts iron.
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              60 Watt can desolder it? wowww. what a tough one..did you check all of parts connected to heatsink?? did you just desolder all three legs rectifier, maybe you forget to desolder the heatsink it self ? it's hard to check rectifier heatsinked when in circuit, maybe u can try desolder the transformer at first because you describe hard to remove the rectifier, as transformer removed, u can check that diodes in circuit to get more accurate result, after you make sure it was leaky, desolder it with all of your weapon and changes it . there is still one ways as i guess. if you can inserting your screwdriver to remove the bolt on diode, just desolder the 5V diode and replace it.
                              btw using flux may help you..
                              Best Regards
                              Rudi
                              Thank You
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • shamsudeen
                                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                by shamsudeen
                                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                07-19-2025, 07:14 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
