A solution addressing dimmer incompatibilities in LED lighting
  • japlytic
    • Oct 2005
    • 2086
    http://www.youtube.com/watch?v=-BVX4GapNpQ
    I think this was easier to implement using a digital controller on the lamp.
    Re: A solution addressing dimmer incompatibilities in LED lighting
    Not unique though
    http://www.fairchildsemi.com/about-f...ompatible.html
    http://globenewswire.com/news-releas...ght-Bulbs.html
    • tommy97
      MacBook A1932 & A2337 MDM - Permanent solution?
      by tommy97
      we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
      06-18-2025, 02:43 AM
      Lithonia Lighting versus Light of America Compact Fluorescent product quality
      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
      I also have back when Light of America had these light bulbs available for yard lights
      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
      While the Lithonia lighting fixture has all most certain bulb failure
      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
      I have only had this light fixture for not more than a year if it...
      07-02-2023, 03:45 PM
    • bohaboha
      DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
      by bohaboha
      I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
      03-06-2024, 12:59 PM
    • Fernon@Repair
      Gigabyte h310m s2h rev 1.1 Keep Restart solution pls
      by Fernon@Repair
      Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
      I allready checked
      VCCPLL voltage ok
      VCCIO Voltage ok
      VCCIO Enable ok
      VCCSA Voltage Ok
      VCCSA Enable Ok
      VRM IC voltages ok
      Replaced VRM IC
      Replaced LM358 ic
      Re programed Bios
      But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...
      07-08-2025, 10:16 AM
    • onextwo
      LED lighting batten drivers
      by onextwo
      In my workshop I have 12 LED lighting battens and the some of the drivers have failed.
      In side there is 2 aluminium PCB with a 72 LED on each PCB as ‘current' Schematic.
      I am looking the get some constant current led driver to replace them.
      is it there any problem wiring as ‘option 1' Schematic or is it best as ‘option 2' Schematic.
      With option 2 I would have to modify the all PCBs, so a lot more work.
      08-17-2024, 01:10 AM
