Re: How do I make this AC fan run?
You just want to lower the voltage for the main winding, but not so much the start-winding takes over, doing all the work.
A series capacitor (with the main winding) can give lower voltage to the motor. But it's a big ugly cap found in larger induction motors start caps, which I am saying use one here as a series cap (not for starting).
You don't want the start-winding doing all the work. I didn't mean change the start cap from the factory 4uF, although that value is "tuned" to the motor's operating speed and at lower speeds the larger phase shift I think needs a bit bigger cap? For best efficiency.
An old transformer connected as an autotransformer would also work. Say giving 195VAC (using a 220V-25VAC sec. xfmr). This is what I use (or old UPS autotransformers) , or a variac. A 10% drop in voltage gives much more drop in speed.
I hope this gives you some ideas but I am not an expert. It's great you are keeping an eye on PF and current draw, as you can slow the motor down but make a ton of heat if it's done poorly.
Half of the computer problems is caused by bad contacts
