I have been trying to find some in depth information on capacitor chemical composition and one thing that I can seem to find is are the insides of capacitors acidic or basic or neutral? THe reason I am wondering is that I have acess to a lot of expensive equipment for chemical analysis, and I wanted to try and do some comparisons between the good capactiros and the bad ones. My idea:
Extract the electrolyte using a solvent.
Run a few IR scans to compare them (not entirely helpful but could give some info)
Then run a GCMS which would split a sample into its individual parts and then analyse it. The idea I am wondering is could be use it to track changes in the caps over time (not on the same cap but as companys alter the chemical formulas etc.) to see if we can spot good and bad quickly via chemicals. For example say a little known cap comes into play, we could see if it compares to a nother well known bad cap etc. The problem is, highly acidic compounds will destroy a GCMS capillary collumn, also compounds containing a labile fluorine will kill the column. I am unsure if anyone in here could answer this question, but I feel like this would be a nice side project for me. The hardest part will be finding a solvent that extract all of the electrolyte (though most of the aqueous ones should be fine in water).
), the solution is probably more alkaline (in order to generate the AL oxide layer). But the purity of the used Alumina on the foils are a major factor too. There is an link burried deep in this forum, where some pro`s died some testing on bad caps from Taiwan. They stated, that the Al from Japanese capacitors was nearly 97.xx% clean or may be soemthing near 99.xx% wheras that from badcaps are only 96 or lower purity. They further explained, that if the purity is to low, an excess of hydrogen would be generated, wich are responsible for the bulging and early elektrolyt breakdown show by the bad caps.
