Self-discharge electrolytic capacitors
  • capator
    • Apr 2013
    • spain
    Hello.
    I have understood that an electrolytic capacitor has a self healing effect when disconnected in such a way that, when it is disconnected after being charged in DC, its self-discharge resistance is much bigger that the resistance when was connected across the DC voltage.
    Am I right? How much bigger?
    I would like to know in depth this phenomena, could you bring me some hints about it ?
    Thank you very much.
  • MDOC
    EngineeringTech
    • Mar 2010
    • 146
    Re: Self-discharge electrolytic capacitors
    No, because of the phrase you mentioned: "when it was connected across the DC voltage." In that configuration, there is no discharge because DC is continuously applied to it. If the phrase is modified this way: "when it was connected across a bleed resister to ground," you'd be right. But, without connecting the cap's leads to themselves or to a circuit, there is little or no discharge.
    • cheapie
      null
      • Jul 2010
      • 849
      His post makes almost no sense... I think he's trying to talk about reforming.
        Not sure if he is asking about self-discharge, the charged cap will self-discharge (when it is disconnected from the source) the due to internal leakage resistance.
        • MDOC
          EngineeringTech
          • Mar 2010
          • 146
          yes, there is some discharge, how much I don't know but depends on the size and capacitance. Big caps can hold a charge for a long time.
            http://www.analog.com/library/analog...ersary/21.html
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Capacitors always self-discharge (except when at a low voltage - they can have a battery effect!). Even when there is power being applied across the capacitor, it is discharging, but the power source keeps refilling the stored power reservoir (the capacitor/capacitance). This discharge is called leakage current.
              The datasheets for the capacitors will specify the leakage current. A capacitor discharging fast, with no external power source applied, means either the leakage current is high, and/or the capacitance has dropped. Don't mistake this when evaluating a small value capacitor!
              Muh-soggy-knee
              • MDOC
                EngineeringTech
                • Mar 2010
                • 146
                OK - but I meant that a cap removed from a circuit will hold a charge - there is no discharge.
                  It will still have self dis-charge due to it leakage resistance, Rp. Very important in high Z circuits.
                  Read the link on post 6.
                  • MDOC
                    EngineeringTech
                    • Mar 2010
                    • 146
                    No. This leakage (Rp) is through a resistor in parallel with a cap. A cap, especially a large electrolytic one, will hold a charge if cap is removed from a circuit. The charge will dissipate eventually over time, but too slowly enough that it will still hold a charge.
                      Charge up the cap and see for yourself if it will hold the same voltage, that Rp is in parallel with the cap since no cap has perfect insulation between the two plates, it has very high resistance which will eventually drain the cap.
                      The Rp represent the real world cap circuit, not the circuit resistor.
                      If you design high Z circuit, you will know how important of the Rp will be. The leakage current can be in uA or mA range, no cap has perfect insulation between the two plates.
                      http://www.newton.dep.anl.gov/askasc...0/phy00900.htm
                      https://cdn.badcaps-static.com/pdfs/...bcd99f6e92.pdf
                      • MDOC
                        EngineeringTech
                        • Mar 2010
                        • 146
                        Depends on the cap design. Had a cap pop on me years ago in class after several minutes.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          What do you mean?
                          Muh-soggy-knee
                          • Ahakim
                            • Apr 2013
                            • 64
                            It seems that what you mean is not what we understand... Would you please rephrase your inquiry about cap discharge. You will get the right answer/explanation...
                            • MDOC
                              EngineeringTech
                              • Mar 2010
                              • 146
                              Originally posted by ben7
                              What do you mean?
                              I meant that soon after charging up a large cap, the cap was shorted, and there was a loud bang. A period of time, I don't remember how long.
                              • MDOC
                                EngineeringTech
                                • Mar 2010
                                • 146
                                I believe it was much longer than several minutes... hours. Certainly less than 24 hours.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Yeah they can hold a charge for days!
                                  Muh-soggy-knee
                                  • RetroComputingGrotto
                                    Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                    by RetroComputingGrotto
                                    I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                    As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                    What is your advice/opinion on whether or not on old(er)...
                                    04-03-2024, 08:30 AM
                                  • alfredo2j90
                                    Old electrolytic capacitors
                                    by alfredo2j90
                                    So as most of us know, old unused electrolytic capacitors are unrealiable due drying out and breakdown of the oxide layer.
                                    I have a few questions regarding these issues.
                                    1. Does using an electrolytic cap stop it from drying out or is it natural process that happens regardless?
                                    2. With the breakdown of the oxide layer the ESR will increase as well as DC leakage. Say the cap has remained unused on a motherboard, psu or games console for many years, if the cap does not physically pop when power is applied what other damage could occur to the system if it was...
                                    10-10-2021, 04:43 AM
                                  • P4C800
                                    ASUS P5A and P2B-S recapping. Searching old datasheets.
                                    by P4C800
                                    I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                                    There are three mainboards:
                                    - ASUS P5A rev 1.04
                                    - ASUS P2B-S rev 1.03 "Rubycon"
                                    - ASUS P2B-S rev 1.03 "Chemi-Con"
                                    If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                                    They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                                    P5A
                                    10-09-2023, 05:55 AM
                                  • slybunda
                                    AA and AAA battery charger capacitors?
                                    by slybunda
                                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                    it has inside:
                                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                    2 x 470uf 16v LZ105c branded as G.Luxon
                                    not heard of these brands are they any good?
                                    iv attached photos of the charger and the board inside for an idea on the type of...
                                    12-24-2023, 04:41 AM
                                  • proxneo
                                    Recapping Sony ICF-SW55 - verifying cap values
                                    by proxneo
                                    Dear reader
                                    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                    At the moment, I have selected replacements based on the following list of values:
                                    3 x 470uF 10VDC
                                    3 x 4.7uF 35VDC
                                    4 x 47uF 50VDC
                                    8 x 22uF 6.3 VDC
                                    1 x 220uF 6.3VDC
                                    5 x 100uF 6.3VDC
                                    Which...
                                    06-21-2023, 12:38 AM
