Tms92903ct
  • zoki77
    • Macedonia
    Tms92903ct
    What means the marks after TMS92903CT like E 08TM14 B?
    And can i replace with TMS92903CT G 08TM41 E?
    I have monitor Samsung P2450 and i wanna replace the inverter with the second one. Is this OK?
  • redwire
    • 3912
    Re: Tms92903ct
    Markings after the main part number are usually the production date and line number i.e 2008 week 14 or week 41. It might have a day of the week or hour too. This is to track down defects and quality problems.
    The main part number for the inverter transformers match , so I would be fine changing it.
    • zoki77
      • Macedonia
      Re: Tms92903ct
      tnx redwire
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        11-16-2025, 12:34 PM
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
      • eccerr0r
        A modified sine wave inverter + a grid tie inverter?
        by eccerr0r
        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
        Next thing is trying to charge the batteries using solar power, but that's another issue ...
        08-31-2023, 09:14 PM
