Replace capacitor...
  • bauto601
    • Sep 2012
    • 103
    • Netherlands
    Ik am a newbie in this but i want to try this: I have a 3A 12V psu from a lcd and it has a bad 400V 47uF cap. I don't have 400V 47uF caps but i do have 2 200V 300uF caps from a chinese pc psu. Can i replace that bad cap with 2 200V 300uF caps so i have 400V 300uF? Or is it bad to replace a 47uF cap with a 300uF cap?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Replace capacitor...
    No, you would need a single 400V capacitor. You could increase the capacitance a little though if you wanted.
    • bauto601
      • Sep 2012
      • 103
      • Netherlands
      OK, thanks for your answer. The only option is buying a new cap then...
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        You should check but I believe that to get 2 caps to = 400v in a DC circuit you have to connect them in series. 2 300uf caps connected in series would have a total uf of 150uf.
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • mikkele86
          Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
          by mikkele86
          Hello Im renovation a Luxman R-5045
          On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
          because thats what i got in stock :/
          04-16-2024, 12:37 PM
