Capacitance of a Capacitor
  • iamakda
    • Mar 2012
    • 46
    • Denmark
    Dear all,
    which formula is correct for the calculation of the capacitance?
    1). C = k*e0*A/d or 2). C = e0*er*A/d ???
    e= epsilon
    A=area of the plates
    d=distance between the plates
    k=dielectric constant
    and if i want to calculate the capacitance in Farads then in what units the Area and Distance should be:
    Area in m2 or cm2 ???
    Distance in m or cm????
    Thanks for the help.
  • spleenharvester
    • Mar 2010
    • 921
    Re: Capacitance of a Capacitor
    Never seen the equation before but area should be m2 and distance in m, given they are SI Units. I may be wrong.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • Sparklingx
      SMD ceramic capacitor capacitance & voltage
      by Sparklingx
      what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
      09-12-2024, 01:04 AM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
