Large capacitors - any value?
+ More Options
Posts
  • bogart219
    • May 2009
    • 175
    • usa
    Hello everyone and happy easter
    I have five large capacitors that came out of old xray equipment some years back. They seem to charge up and discharge ok (using my digital meter). Is there anything that someone would use these caps for? Is there a better way to test them? Thanks!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Large capacitors - any value?
    just reform them.if the esr is good and no leakage after reforming i would keep em.
    just got one at mendelsons for my friends asteroids.had a 78 datecode.
    reformed just fine.
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      yes they have value.
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • klkmalik
        seeking Tips
        • Nov 2011
        • 68
        • UAE
        This type of caps for high wattage power supply only for using. normally not using this much high value. So keep it some time need heavy equipment psu for repair/
        • bogart219
          • May 2009
          • 175
          • usa
          Thanks for the info fellows. I've used the search function on here but am still confused on how to reform a cap exactly. Anyone got a link to a threas or site that explains how to reform exactly? Thanks!
          • twbranch
            Mad Nerd
            • Oct 2012
            • 153
            Here is a pdf of reforming using a Heathkit cap checker. Works using same principle with others as well.
            https://cdn.badcaps-static.com/pdfs/...b260b00ca0.pdf
            • cheapie
              null
              • Jul 2010
              • 849
              Essentially it consists of very slowly raising the voltage applied until it gets to the maximum rating.
              • newsmartAnn
                • Mar 2013
                • China
                we had purchase this goods before, but you said that they had been long time on ya ,you can testing them use below method
                Detecting capacitance amateur conditions, you can use a digital multimeter with capacitance test functions as a tool, such as DT9205A 1p ~ 200μF capacitor can be detected.
                The professional testing capacitance, need to purchase a "digital bridge" detector capacitance, electrolytic capacitor leakage current tester detects leakage current of the capacitor, electrolytic capacitor voltage tester "instrument.
                • dragon3x
                  by dragon3x
                  power on.
                  Here are some examples :
                  switching supply area).
                  than 6.3 V.)
                  03-21-2025, 02:46 PM
                • slybunda
                  AA and AAA battery charger capacitors?
                  by slybunda
                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                  it has inside:
                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                  2 x 470uf 16v LZ105c branded as G.Luxon
                  not heard of these brands are they any good?
                  iv attached photos of the charger and the board inside for an idea on the type of...
                  12-24-2023, 04:41 AM
                  After all of...
                  07-13-2024, 08:14 PM
                • Ady2017
                  Are there any datasheets available for Elna RJG capacitors?
                  by Ady2017
                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                  05-25-2025, 02:19 PM
                • ctroxtell
                  Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                  by ctroxtell
                  I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                  01-03-2025, 08:57 PM
