Need replacement Mosfet SMK1060
  • cguzek
    • Jan 2010
    • 57
    I have two SMK1060 I would like to replace, can find datasheet, but no one selling them, does anybody know an acceptable replacement that they would sell on Digikey, it is used on a led tv power supply, thanks.
    Included a stock picture, but mine is 21914 not 60819 like it is in picture at the number above smk1060.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Need replacement Mosfet SMK1060
    You can use STP10NK60Z. Since those appear to be in an isolated package, you'll need the FP variant, so the complete part number you are looking for would be STP10NK60ZFP. It's a pretty common part. And yes, they do have it at Digikey: http://www.digikey.com/product-detai...2-5-ND/1039515
    A working TV? How boring!
    • cguzek
      • Jan 2010
      • 57
      Thank you very much, ordering from digikey now. appreciate the help.
      • xpert2k22
        • Jun 2016
        • Qatar
        [QUOTE=cguzek;316908]I have two SMK1060 I would like to replace, can find datasheet, but no one selling them, does anybody know an acceptable replacement that they would sell on Digikey, it is used on a led tv power supply, thanks.
        Included a stock picture, but mine is 21914 not 60819 like it is in picture at the number above smk1060.[QUOTE=Checkout this website for substitute/ replacement: [url]https://alltransistors.com/mosfet/crsearch.php?&struct=MOSFET&polarity=N&pd=40&uds=600&id=10&rds=0.75&caps=TO220F][/url]
        • CapLeaker
          Leaking Member
          • 8123
          In Digikey search for "10N60", click on Mosfets and viola you should get what you asked for!
          • dinesh6252
            • Feb 2020
            • India
            found this thread via google, i have a power supply board which has the same SMK1060 transistor having all three pins are showing shorted on multimeter.i have searched my local electronicc market for it, but cant find this transistor. Can you tell me the transistor features which i need to see when choosing a replacement?
            • DoOm86
              Dual mosfet replacement help
              by DoOm86
              Hello.
              I have a notebook with a shorted mosfet, it's a E6930 GA8125.
              It seems to be a 30V dual asymmetric N-channel AlphaMos.
              Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
              And here is where I need help!
              It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
              I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
              Thanks!...
              10-31-2023, 12:03 PM
            • jm942
              Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
              by jm942
              My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
              I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
              I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
              I did voltage injection on the cpu with 0.7V and i have a current...
              07-11-2024, 05:11 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • String2016
              SMD MOSFET REPLACEMENT
              by String2016
              Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
              01-23-2025, 06:35 PM
            • String2016
              by String2016
              i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
              12-15-2024, 05:31 AM
