ti-nspire with bad lcd screen
  • opamp
    • Dec 2012
    • 160
    • united states
    Has anybody ever tried to fix the lcd of a calculator? is it even repairable? the reason I'm asking is because I can still see the numbers in the background were the paint came off, so I'm thinking maybe separate the lcd layers and repaint the spot??? It may sound silly but who knows. Anyways I'm thinking of replacing the screen but thought I should ask first.
  • Jim@HiTek
    • Sep 2012
    • 4
    Re: ti-nspire with bad lcd screen
    I've tried many methods of restoring LCD screens. I've never attempted to split the glass layers apart because if you do that, the liquid crystal will spread all over the glass, I think. But I have repainted the reflective silver paint on the back of some LCD assemblies.
    Btw, no method I tried ever worked so I gave up.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
