can you recommend soldering tools/supplies
  • ryan74
    • Oct 2012
    • 471
    • usa
    I need to get setup with decent equipment mainly for tv repair. if it works well i dont mind generic.
    soldering station
    desoldering station/gun(or combo)must have good suction
    helping hands or similar
    tip cleaner
    magnifiers
    anything that is commonly used
    first thing i need is to replace my $20 weller iron and $5 sucker
    maybe something like this http://www.circuitspecialists.com/csi701a.html
  • tron
    • Apr 2009
    • 47
    Re: can you recommend soldering tools/supplies
    How To Set Up An Electronics Lab
    http://www.eevblog.com/2011/04/30/ee...ectronics-lab/
    • smason
      • 1652
      Hakko 936 or 888 Soldering Station http://www.frys.com/product/6508443
      Big Blue - Soldapullt desoldering tool http://www.yaotek.com/store/Assets/P...ages/DS017.jpg
      Brass tip cleaner anything like this: http://www.frys.com/product/1563526?...H:MAIN_RSLT_PG
      • ryan74
        • Oct 2012
        • 471
        • usa
        i have a china made sucker similar to that big blue and it doesnt suck very good.(see pic)
        is big blue alot better? i want a 1 handed tool for desolder but you cant beat the price IF it works well.
        • ghiotom
          • Oct 2012
          • 41
          A Hakko 808 desoldering gun is a great investment if you are going to do a lot of component level repairs. May seem a little pricey, but once you use it, you'll wonder what took you so long to get one.
          • smason
            • 1652
            The bigger size does give it more suction.
            Try some vaseline on the o-ring after you clean it, that may help.
              07-01-2024, 06:34 AM
            • chth96
              What soldering station should I purchase for 900M-TJ-I tip?
              by chth96
              hello.
              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
              https://ko.aliexpress.com/item/4001275635593.html
              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
              Any reply would be appreciated.
              11-24-2023, 05:08 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • mkbehbeh
              KSGER C245 Soldering station PSU 220V only?
              by mkbehbeh
              I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
              I am...
              04-17-2023, 03:11 PM
            • Peter_1402
              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
              by Peter_1402
              Hi Everyone,
              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
              1. Soldering iron works great
              2. There is a burnt mark on the hot air gun handle.
              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
              Reed switch tested ok with a magnet.
              From the above test, I can conclude...
              07-12-2025, 11:50 AM
