Help with school problem
+ More Options
Posts
  • shorteddiode
    • 221
    I have been fighting with this problem for hours. If I am thinking right if C3 shorts out it would be like the cap wasn't there and a wire was there instead.
    So I figured C2 and C4 as parellel caps and added them together and which makes 0.02uF. The figured C1 and the 0.02 as a series circuit. I keep getting 0.12 as an answer, which as you can see is not an option. What am I doing wrong??
    If all the caps are good wouldn't the capacitance be 0.15uF? If not I screwed up the other question too.
    I hope someone can explain this to me.
    Thanks in advance
  • mariushm
    • May 2011
    • 3799
    Re: Help with school problem
    I would say 0.3 uF - the short would make C2 and C4 useless.
    Without short, the three 0.1 uF would be equal to 0.3 uF as they're in parallel. So a fictional C5 = C2 + C3 + C4 = 0.3 uF
    Then, C1 and C5 are in series .. which means 1 / C total = 1/C1 + 1 / C2 or 1/Ct = (C1 + C2 )/ C1xC2 => Ct = C1xC2 / (C1+C2) = 0.09/0.6 = 0.15 uF
    However, when the middle cap is shorted, you're left with just C3, 0.3uF
      Infinite. A short circuit would appear like an infinite capacitive load. It would never store any charge (Q = CV) because the capacitance being so large would make V zero (ignoring series resistance etc.)
      • mariushm
        • May 2011
        • 3799
        Well, I put a 330uF and 3 100uF on a breadboard and tested it, then I removed the center 100uF and shorted with a wire.
        With the original circuit, the capacity was 167 uF, which is the right value for 330uF and 300uF in series.
        After shorting, the capacity between 1 and 2 resulted in the capacity of C1.
          Ah, misread the question. The circuit can be treated as a short circuit (wire) connected to the single series capacitor C1, so the capacitance would be C1, 0.3uF.
            It will be 0.3 (the value of C1) since C2 C3, C4 will become just a piece of wire connecting node #2 (you can short C2, or C4 it does not matter) to the bottom leg of the C1.
            This circuit can be resistors also with the same result. You shorted out the component, that component will no longer has any affect.
            You can easily proof it with the real circuit.
            • shorteddiode
              • 221
              Thanks guys,, I think I understand
              • shorteddiode
                • 221
                so what you are saying is the short would talk the parellel circuit out of the equation?
                  Yes.
                  • shorteddiode
                    • 221
                    Thanks Guys, the little light came on and it makes sense now.
                      Great!
                      • shorteddiode
                        • 221
                        OK, let me ask just one more question. If it had been C2 or C4, would it have the same result?
                        • Tube_Dude
                          • Feb 2011
                          • 51
                          Absolutely!
                          • shorteddiode
                            • 221
                            Thanks for all the help everyone
                            • theone111
                              by theone111
                              3. Problem: TV shuts down
                              07-22-2024, 10:36 AM
                            • Zeonalbasta
                              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                              by Zeonalbasta
                              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                              09-13-2024, 01:17 PM
                            • Gibon378
                              Problem with stopping audio and video for no reason
                              by Gibon378
                              PC Specs:
                              • CPU: Ryzen 5 1600
                              • GPU: GTX 1080 Palit JetStream
                              • MOBO: ASRock ab350 PRO4
                              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                              • PSU: XFX 650W (don't remember what model)
                              • OS SSD: ADATA SP920
                              • OS: Windows 10 21H2
                              Problem description:
                              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                              11-19-2022, 09:41 AM
                            • perzyk23
                              Lenovo T580 - LCD Panel problem - error 0288
                              by perzyk23
                              Good morning,
                              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                              10-25-2024, 12:42 AM
                            • SDNarcia
                              Dell 15R-5521 keyboard problem (KBC?)
                              by SDNarcia
                              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                              As additional information,...
                              07-20-2024, 10:47 PM
