Transformer \ regulator question
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    If I had a transformer which provides say, 12v output at 500 mA and I connect a 5v regulator, eg: 7805, since the output voltage is less than half the input, I can get about twice the current, 1 Amp at 5v - right?
    -David VanHorn
  • mariushm
    • May 2011
    • 3799
    Re: Transformer \ regulator question
    No, you'd get 5v at about 450-480 mA. Linear regulators chop the voltage down, dissipating the difference aka making heat.
    7805 is particularly bad because it also has poor efficiency.
    Switching regulators could do more than 500mA, but also themselves are about 70-90% efficient.
    • mariushm
      • May 2011
      • 3799
      Also, pay attention to what transformer you have and how that 12v 500mA is defined
      If it's 12v AC rms then 12v is the equivalent of DC voltage after rectification, ignoring the losses in the diodes.
      If it's not AC rms then it's 12v peak to peak, meaning your actual dc voltage will be much smaller after rectifying the voltage and the current output will be different - the maximum power the transformer outputs remains the same VA = volts x A
      But you have to keep in mind the bridge rectifier (or the four diodes) that convert the AC to DC - at any moment two of those diodes conduct, so you have a loss of 2 x 0.3-0.7v when rectifying the voltage.
      See this page for more about ac / dc : http://www.kpsec.freeuk.com/acdc.htm
      • Agent24
        I see dead caps
        • Oct 2007
        • 4981
        • New Zealand
        OK, but in general, if I used a switchmode regulator, I would be able to get a higher current out than in, along with the drop in voltage?
        Is there an easy way to calculate how much would be provided for a certain input or how much would be drawn for a certain load?
        -David VanHorn
          12V transformer with 500mA AC, the max current from the Fullwave rectifier circuit will be about 300mA DC continuous from the transformer.
          • mariushm
            • May 2011
            • 3799
            I've edited my previous comment a bit, because it was somewhat incorrect.
            You can check the datasheets of various switching regulators to see how well they can do the conversion.
            For example check this one: http://www.digikey.com/product-detai...-5.0-ND/363828
            and the datasheet is here: https://cdn.badcaps-static.com/pdfs/...8809810ac8.pdf
            The datasheet says it can do up to 92% efficiency, but at page 6 there's a small graph efficiency vs input voltage, which tells you that it's kind of 85% efficient with 12v input.
            Keeping in mind that you won't get perfect parts and exact resistors and so on, assume it's 80% efficient.
            Then, 12v x 0.5 A = 6 watts ... 80% efficiency means 6w x 0.8 = 4.8 watts ... so your switching regulator might do 4.8w / 5v = 0.96A
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              Hmm, that's even worse going by that transformer datasheet...
              12v @ 0.5 A I chose just for an example, but I don't know if this is going to work. Maybe I need a bigger transformer
              I have actually a 16v @ 1.5A transformer and I wanted to get 12v at about 1.65 - 1.7 Amps.
              -David VanHorn
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                That should work with a switching reg, the difference is small. It won't work with a linear tho.
                A working TV? How boring!
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  I guess I'll just have to try it out and see...
                  -David VanHorn
                  • ohren
                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                    by ohren
                    Hello!
                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                    Measured voltages with no load:
                    After rectifier diodes
                    12V: 6.17 V
                    5V: 5.67 V
                    Secondary transformer pins AC measurement (really don't know if this says anything)
                    12V: 2-2.5 V
                    5V: 1.04 V
                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                    03-18-2023, 10:33 AM
                  • mikey5791
                    Is it possible for transformer substitution?
                    by mikey5791
                    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                    My questions are
                    1. How do i test to see if the transformer is in good working condition?
                    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                    Hope you guys understand what i was asking. My intention is...
                    11-03-2022, 02:11 AM
                  • dennis_elx33
                    3PHASE STEP-DOWN Transformer in Check
                    by dennis_elx33
                    Hello All,
                    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                    Problem statement: Power tripped Off
                    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                    Action Done:
                    1) Replaced the faulty parts with good spare.
                    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                    12-02-2024, 06:52 AM
                    ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 04:40 PM
                    ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 12:00 PM
