Solid state caps v/s Electrolytics?
  • Super Nade
    • Jun 2006
    • 294
    Hey guys,
    I was wondering if there are any advantages of using SS caps v/s electrolytics. Gigabyte are marketing their newest board (965P-DQ6-6Q) as having "all solid state caps". Are those caps guarenteed to have lower ESR than Electrolytics, or is it marketing bullshit?
    Here is a "preview" of the board. Are those Sanyo caps ?
    http://www.xtremesystems.org/forums/...d.php?t=108590
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • tiresias
    • Feb 2006
    • 489
    Re: Solid state caps v/s Electrolytics?
    As far as I've seen, Sanyos will often have "SEPC" marked on their tops, while UCC ones will have a little logo above their marking.
    The pic you supplied is a little small to be sure, but I've posted a few pics of my board, with emphasis on the caps - perhaps you can compare them to your gigabyte board. (The CPU VRM inputs are 16V UCCs, and the outputs are Sanyo) http://www.liesbeth.org/forum/viewtopic.php?t=212
    • arneson
      • Sep 2005
      • 1267
      I thought finally, major advance , looked at all pictures of boards, but no solid state caps.
      I guess you mean solid polymer.
      Jim
      • Super Nade
        • Jun 2006
        • 294
        Arneson, what is the difference between the two?
        Thanks for the pictures tiresias. Now, what would these caps be?
        This is Panasonic, right?
        I found a few Tosin's as well:
        Are these Chemicon?
        Q6700 @ 3.6 GHz
        Zippy GSM-6600P
        Abit IP35Pro
        ATi HD4870
        • arneson
          • Sep 2005
          • 1267
          I'll call it, synthetic capacitance, is a chip performing the functoin of capacitors. It requires support circuitry including small capacitors but the filtering is solid state.
          Symantics, solid state at least to me is silicon or germanium or such and that could change any day.
          Jim
          • Shroomie
            • Apr 2006
            • 356
            Yep, you got the brands right.
            I'd like to see how those Tosins do. I've seen a few working fine in PSUs, but never on a motherboard.
            You know there's something wrong when you open up a PSU and are glad to find Teapos.
            Why I don't buy cheap cases!
            • gonzo0815
              • Feb 2006
              • 1600
              I think this solid polymer hype is somhow marketing, as in generall, is is ok to use al caps, as long as they are from an reputable brand. But anyway, for higher ocing may be there are some benfits, but in generell they are laking in bulk capacitance. In my opinion it would be the best to use those caps as vrm input, and some high capacity al caps as o/p caps. this would be probably the best desing.
              • Rainbow
                • Aug 2005
                • 1371
                I wonder if they stop using GSC crap on all the other (not-the-most-expensive) boards...
                • tiresias
                  • Feb 2006
                  • 489
                  But what if GSC starts making their own polymers too?
                  • Rainbow
                    • Aug 2005
                    • 1371
                    First leaking polymer caps?
                    • Super Nade
                      • Jun 2006
                      • 294
                      Hey guys, I couldn't figure out what the Red Aluminum one was? First pic.
                      The MB BTW is the new ASUS M2N-E (AM2 non-SLI). I'm building this for my Uni. Next on the list is a "mini" cluster with about 20 computers. Best part is, I get to order the best of the best. For the Cluster, I may go with Kentsfield, depending on if it crunches better than the Socket F Optys.
                      Q6700 @ 3.6 GHz
                      Zippy GSM-6600P
                      Abit IP35Pro
                      ATi HD4870
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
