finding correct caps
  • littlejon
    • Aug 2012
    • 20
    • sweden
    Hi people. I have another bad PSU this time it seems like some of the caps are bad. It's a LG monitor.
    I'm still learning so I need to ask a this.
    There's 6 caps all near each other 4 are Suscon 16v 680uf 105 and 2 are Panasonic caps I think.
    I'm still not sure if I need to find an exact replacement or not, obviously they have to be the correct v,uf, temp range but do I need to source exact replacements.
    The suscon are
    16v
    105c
    1000uf
    size 10w x 20h
    The Panasonic (if they are)
    16v
    105c
    1000uf
    size 10w x 20h
    these have an (M) and also pet on the side which I beleave stands for polyester?.
    I'm unsure about the 2 with pet on the side, is it super important or not.
    Hope someone can help.
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: finding correct caps
    The Panasonic caps are definitely not polyester. Both the Suscon and the Panasonic parts are electrolytic caps. I'm guessing the "M" might be the Matsushita logo. Beyond that, we need to know the series of the parts. For example, "FC" and "FM" are common Panasonic series. Knowing this information is necessary to know certain critical characteristics so as to recommend similar parts. I'm not familiar with Suscon, except I'm pretty sure they are not respected here on BadCaps.
    PeteS in CA
    • selldoor
      Slow Learner
      • 7870
      PET =Polyethylene terephthalate the substance the plastic coating is made out of.
      Bit surprised if the panasonic caps are bad - can you do a picture.
      I would replace all with panasonic FR FM and FC in that order best- less good. but you
      need to get the physical size correct.
      • littlejon
        • Aug 2012
        • 20
        • sweden
        Thanks for the reply's, yes PET =Polyethylene yes that's the one. So there's nothing special about these really. I also notice someone mentioning suscon as being rubbish.
        Here's some pictures hopefully they will help, the size of both are Hight 20mm Width 10mm
        The first 2 pics front and back there are 4 of these
        The 3-4 pic front and back there are 2 of these.
        • mariushm
          • May 2011
          • 3799
          Ok, so they're not Panasonic.
          They're
          * Su'Scon SG :
          * Samwha WB: (page 32, WB is discontinued... Samwha recommends to use MK series instead)
          Replace with capacitors with >= ripple , <= impedance .. basically Panasonic FR, FM, FC like selldoor said would be good.
          • littlejon
            • Aug 2012
            • 20
            • sweden
            Thank you very much for taking the time...will be my first go at fixing a PSU.
            • selldoor
              Slow Learner
              • 7870
              Good Luck!
              If you get stuck start a new thread in the troubleshooting computer displays forum
              • PeteS in CA
                • Aug 2005
                • 3583
                mariushm posted much of this, but "translating" ...
                Su'scon: Probably the SG series; made in the 33rd week of 2008; M = +/-20% tolerance
                Samwha: WB is probably the series; M = +/-20% tolerance; W8A is the date/lot code; PET does seem to mean polyester, possibly referring to the sleeve (major brands switched from PVC to polyester sleeves in their RoHS-compliant parts, so PVC may in some way be politically-environmentally incorrect)
                PeteS in CA
                  by momaka
                  03-12-2025, 03:42 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • BigPete
                  Panasonic Heatpump Dryer Repair
                  by BigPete
                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                  Unfortunately the whole machine has to come apart to fix it.
                  I have...
                  11-01-2025, 06:40 PM
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
                • quickname
                  Cyberpower 1500AVR UPS repair
                  by quickname
                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                  I decided to verify that the batteries were...
                  11-12-2023, 09:57 AM
