Any one have any advice for CCFL to LED convertion?
  • jeffescortlx
    • May 2011
    • 40
    An Acer x193w 19" monitor was given to me. It has a bad CCFL.
    I want to convert it to LED backlit.
    This is the LED's I have picked out:
    http://www.mouser.com/Search/Product...rkeXLRgw%3D%3D
    They are a white "9000 K" (how ever white that is) short 5mm. (hope it fit's)
    "Through Hole" so I can just solder them up, in series groups of 4 (they are 3.2v each).
    I'm just gonna use the 12v supply that's there for the inverter, and use a transistor off the inverter enable trigger signal to turn them on.
    They are a 110ยบ LED, should have a nice wide beam so I don't get bright stripes. I'm wondering if I can get away with 8 on top and 8 on bottom. I could do 12 or 16 top/bottom.
    So it will cost $3.04 to $6.08.
    Any one have any advice? Will they fit in place of the CCFL lamp, and will the Wavelength/Color Temperature of 9000 K be white enough to not screw with the display color?
  • JimmysTGP
    • May 2012
    • 45
    • US
    Re: Any one have any advice for CCFL to LED convertion?
    You sure got me thinking about something like this, However you do understand that theirs active lines that go to each LED array, which may make the Brightness seem to high in some areas and the contrast seem low in others. Thats the reason why they calculated all these factors in to be able to get the best whites and blacks to the areas neccessary. But the Idea would most definitly have my interest if you were to take this project on. Fill us in on the progress if attempted.
    • 999999999
      • Sep 2006
      • 774
      I doubt it's going to work out well for 3 reasons.
      1) 9000K is a very blue tinted light. Typical CCFL is closer to 5K though I'm not sure about those in monitors. You might or might not be able to boost red and green and reduce blue with monitor controls or the video source but you're already at a disadvantage.
      2) They won't produce nearly as much light as a couple CFL tubes.
      3) It'll be unlikely that they end up producing uniform light. Even when professionals design lighting systems with CFLs, even they can't avoid a little bleedthrough around the edges.
      • jeffescortlx
        • May 2011
        • 40
        I am moving forward with this project. The LED's came in a few day's ago.
        I haven't had a chance to install the LED's yet, but I did test one of the LED's to get an idea on how well/bad it will go.
        So far, I think it might work out OK. It's a lot less blue then I was expecting, and the beam is spread out very wide, so I don't think I will see any streaking or bright strips of light. It wasn't super bright, with a lit room, I could light up my hand about 10" away. But I will have 16 on top and 16 on bottom, and it's only a 19" panel, so I'm confident I'll have plenty of light.
        And if it turns out a failed project, I'm only out $6 for parts and $6 for shipping.
        I had gotton the monitor for free, and my other option was to just throw it away.
          Do you have any plan yet for dimming?
            master hoarder
            • May 2008
            • 12170
            Keeps us posted how it goes.
            I have an old 15" LCD I want to put LEDs in since it has a dead CCFL on the bottom and the top one is very dim (probably on its way out too).
            I'm thinking if I should use pre-built LED strips, though. They are very cheap on ebay, and you won't need resistors or drivers or anything like that. Just hook them up straight to 12V.
            However, the only concern I have about those LED strips is the quality. Currently we have 2 sets at my workplace, both working 12 hours a day for the past 2-3 months. One of them has started to develop many dead or dim LEDs, while the other is fine. The LED strips are from different companies, though, so I guess there's a bit of luck involved there. So if anyone decides to use cheap LED strips from eBay, just be advised of their quality.
            I don't know about dimming, but he will definitely need to do something about driving them properly so they don't burn out. Most simple way would be to put 3 LEDs max in series and then use a resistor to drop 2.4V with a resistor. The resistor should be chosen to allow the proper current to the LEDs.
            Since these LEDs are rated for 25mA @ 3.2V each: 3 of them in series will require 9.6V @ 25mA to run. That means the resistor will have to drop 2.4V. So the resistor value will need to be 2.4 V / 0.025 A = 96 Ohms. A 100 Ohm resistor should work fine.
            Before putting the LEDs in the screen, I would strongly advise to use a multimeter to measure the current going to the LEDs to see if any adjustments need to be made to the resistor values.
            If you want dimming, I would guess the easiest route would be to use a PWM controller.
              He will need to build analog variable constant current source for Dimming, max current will be about 30 mA and go down from there. Or PWM using 555 TIMER.
              • jeffescortlx
                • May 2011
                • 40
                Yep. Set it up, and if it's too much light, I'll add resistance until it looks good.
                I really dont see the need to go over board on a monitor that can be replaced in good working order for 40 bucks on craigslist.
                I looked at these at mouser, and they were all pretty expensive.
                Plus with individual LED's I have a little more freedom with spacing and voltage control.
                Since these LEDs are rated for 25mA @ 3.2V each...
                The 12v power supply is on the high side, so I can use 4 in series. I might not need any resisters at all, but I'll check the voltage across each LED and measure the current once I get it set up.
                • 999999999
                  • Sep 2006
                  • 774
                  You'd be better off with 3 in series and a resistor to limit current so you have the (nearly) exact drive current you want.
                  • jeffescortlx
                    • May 2011
                    • 40
                    True.
                    But, I'm putting this project on hold until I run across another panel with bad back lighting. I was given a used panel that was intended to be used to scavenge parts from. It wasn't suppose to work, but just for the heck of it I hooked it up and it's been running great all afternoon.
                    The screen is in better shape then the one I was going to do the conversion to.
                      master hoarder
                      • May 2008
                      • 12170
                      Under $2 on ebay with free shipping from China. The only downfall is the slightly longer wait times. I think I will buy a set for my 15" LCD if I find the right size. Maybe even a few more for other various projects.
                      True.
                      Just like diodes, LEDs are highly non-linear devices. That is, near their turn-on voltage, their resistance changes quite drastically. So for example, at 3.15 V your LEDs may be very dim, but near 3.2 V, they may be fully bright, and near 3.22 V they may burn out. Most switching power supplies (LCD, PC, and other electronics) tend to have +/-5% tolerance - more than enough to make your LEDs either too dim one instant and burn out the next.
                      To get even brightness from your LEDs without having the PSU variations affect them, you need to control the current going to the LEDs.
                        ACER Predator Orion 9000 Predator Orion 9000 i9-7900X Specification for Upgrade or Repair
                        This specification for the ACER Predator Orion 9000 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 9000 boardview and Predator Orion 9000 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-12-2024, 03:28 PM
                        ACER Predator Orion 9000 Predator Orion 9000 i7-7800X Specification for Upgrade or Repair
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                        ACER Predator Predator Orion 9000-600 I81070-01 NL Predator i7-8700K Specification for Upgrade or Repair
                        This specification for the ACER Predator Predator Orion 9000-600 I81070-01 NL can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Predator Orion 9000-600 I81070-01 NL boardview and Predator Predator Orion 9000-600 I81070-01 NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                      • mikey5791
                        Help on Samsung Syncmaster T220 dead ccfl lamp
                        by mikey5791
                        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                        10-18-2020, 03:17 AM
