Question regarding diodes
  • daftpunker
    • Dec 2010
    • 5
    Hi guys,
    I have a problem finding the right diode for my application. I need to put 2 power supplies (different types) in series and need to protect each of them from reverse currents using diodes. I believe that they already have diodes built in, but I want to take precautions.
    So my problem is that I am not sure which diodes to order.
    One power supply is 52V, 30 Amp and the other one is 30 V, 20 Amp. the circuit will be powered at 72 V and current could increase up to 12.5 Amp.
    Since I am not experienced with diodes I am wondering which ones to choose.
    I have the following diodes (1N5402), but I believe the current rating does not match.
    I found these: http://www.digikey.com/product-detai...ICT-ND/2242770
    Do you think they will be appropriate?
    Thanks so much
    Re: Question regarding diodes
    If you are going to have 12.5A or more flowing through the Diode, the Vf at that current will be about 1V or more, so at 12.5A, the Diode must be able to dissipate at least 12.5Watts of power. You should get the Diode that can handle at least 25Watts which more likely that it will have to be mounted on the heat sink.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Maybe I'm missing something, but I think you could use a 60V Schottky, maybe a 20A or 25A rated part (30A or 40A would be even better, but the package might be TO-247 instead of TO-220). That would bring your V(f) down to .6V or .7V, dissipating significantly less power. However you do it, you will need to be able to dissipate a fair amount of power, and heatsinks are not tiny or light.
      PeteS in CA
      • daftpunker
        • Dec 2010
        • 5
        Thanks for the help.
        I would like to avoid the use of heatsinks.
        Couldn`t I use multiple diodes in parallel? Let`s say 4 diodes rated to 3 A in parallel.
        Do you see any problem with this solution?
          You need room for safety margin, usually x2.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Well, one might have a lower forward voltage drop than the others, even if it is minuscule, it might make the diode fail (short circuit from over-current) after a while.
            Muh-soggy-knee
              It is not good to parallel the Diode either unless you use resistors to balance them out or match the Vf really well, the Diode with the lowest Vf will conduct, the one with higher Vf may not conduct at all.
              • 999999999
                • Sep 2006
                • 774
                This is a bad design, something is bound to go wrong. Two PSU, different currents, etc.
                Can you electrically make something work? Often. Does that make it a good idea? The simplest solution is usually the best one. I may be wrong, you might be stranded on a deserted island with no way to communicate with the outside word or order parts. Otherwise, I hope nothing goes wrong but predict something will, sooner or later...
                I'm kidding a little, but not entirely.
                • Evil Lurker
                  Warranty Voider
                  • Feb 2011
                  • 454
                  Your looking at three terminal diode type devices, probably one or more STPR1620 ultrafast or BYW series.
                  • Dvsr
                    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                    by Dvsr
                    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                    After replacing the caps I started testing out the speaker. It seemed...
                    09-10-2025, 10:20 AM
                  • caspian
                    What Zener Diodes on a Linear Power Supply
                    by caspian
                    Dear members,
                    I have a linear variable power supply with unknown brand name that I used for voltage injection.
                    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                    In addition, I discovered that its zener diodes are defective.
                    I can replace the burned transistors.
                    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                    Therefore, I cannot replace the zener diodes.
                    I do not want to test the zener diodes in a test circuit to discover their model or value.
                    no schematics are available...
                    05-26-2025, 12:38 PM
                  • asr
                    Finding replacement diode iPad Pro 3rd gen A1701
                    by asr
                    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                    07-09-2024, 06:24 PM
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                  • NicRac
                    monowheel repair,Is the diode the problem?
                    by NicRac
                    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                    First of all, I am new here. Therefore I will shortly introduce myself.
                    I am Nico and currently I study Physics.
                    In my freetime I like to build and repair stuff. Especially big battery's.
                    A few years ago I got myself an electric unicycle, monowheel or however you call that.
                    The battery bms was broken so I replaced and resolder that. Nothing big.
                    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                    07-26-2024, 06:13 AM
