Fan control circuits
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I was trying to drive a 24v DC fan with PWM, which didn't work. A friend googled it for me and found out that DC brushless fans cannot be driven by PWM as they have their own internal controller based on that hall sensor.
    A bit more googling on my side revealed this: http://www.maxim-ic.com/app-notes/index.mvp/id/1784
    I built the "DC-DC mode, low side" circuit presented there, as it only required an inductor, cap and diode added to my existing PWM circuitry. It works great. I used a 100uH inductor, 100uF capacitor and a random diode from my junk box. PWM frequency is 30kHz.
    Hope this comes in useful.
    A working TV? How boring!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Fan control circuits
    But I have seen 120mm DC Brushless case fans with three pin PWM connectors... I'm aware that on some fans, the third pin is just a dummy wire - and then it is usually colored white. Maybe I am confusing it with sleeve bearing.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      On 3 pin fans the 3rd wire is for rpm sensing, the fan can still be driven by DC voltage only. 4 pin fans are the ones you are thinking about, those are a different animal.
      • lti
        • May 2011
        • 2547
        How do all of those PWM fan controllers work?
          You *can* drive brushless computer fans with PWM, but the mistake a lot of people make is trying to use a high frequency like a few kHz, which will usually cause the fan to twitch, and not spin up properly. You should use around 30 Hz, which gives the fan plenty of time to start on each cycle... the inertia takes care of the rest.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            That would be unacceptable in my application. Try keeping a 30Hz square wave out of a power supply in an audio circuit. FYI, the PWM controller i built originally used something like 200Hz, and the fan didn't work with that.
              Then use 5-10 Hz. And decouple it (>470uF) with a large series inductor (>100µH.) It will create a little beating effect, but barely audible. 30 Hz just gives essentially continuous movement for an 80mm fan. Or, place it on a separate tap on a negative rail, so the noise gets reflected into the negative rail, and not the ground. (This is done in a lot of PSUs.)
              • mariushm
                • May 2011
                • 3799
                Why bother with all these improvisations when you can use something as simple as a MC34063 ...
                http://uk.farnell.com/texas-instrume...ip8/dp/1053579
                The rest of the parts, a couple of capacitors and resistors, a diode and an inductor are all less than 1$ in total.
                  master hoarder
                  • May 2008
                  • 12170
                  Indeed you can drive a fan with PWM.
                  I was actually able to drive all of my fans more or less fine at 5kHz. However, the high frequency does indeed create some problems. Mainly, you won't be able to start the fan at low speed. Instead, you'll have to have the duty cycle cranked nearly 90% or more so that the fan spins, and only then you'll be able to turn the speed down. And if you are using a fairly low KHz audible frequency like I was, you'll get alwful screeching sounds from the fan.
                  I found a solution around this, though - just place an electrolytic cap, 100uF or more, in parallel with the fan. It removes the noise and allows the fan to start even at low speed. The bigger the capacitor, the lower the speed at which you can start the fan. With a 470uF general purpose cap, I was able to start my fans at around 6V (normally most of them would start at 5V if fed DC).
                  The PWM circuit I used looks exactly like this (with the only difference being that I used a FQP19N20C MOSFET):
                  http://www.dprg.org/tutorials/2005-11a/index.html
                  Some old (and cheap) motherboards actually used to use this same method to get the CPU VCore voltages (except that the MOSFET is on the high side). I even have one like that - it's a crappy socket A motherbaord (ECS perhaps?) that I got with a dumpster computer. Came with a 750 MHz Duron. Works well enough for testing stuff.
                  Now if you just replace the diode with another MOSFET and have it turn on when the other MOSFET is off, you'll have a synchronous buck PWM DC-DC circuit .
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                    Corsair CX750M [Model 75-002019] - burned output toroid inductor
                    by momaka
                    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                    09-19-2021, 08:44 PM
                  • delir66
                    How to fine control a brushless dc motor
                    by delir66
                    Hi, I'm building a pottery wheel for my wife.
                    Since it needs to reverse direction and have a nice control over rpm, I decided to pick a diy electric scooter motor.
                    It operates at 48v and comes with a controller.
                    It has three wires for speed control
                    -5v
                    -gnd
                    -signal.
                    The problem is that if I use a 100k pot, motor starts spinning when 1.4v and will get to max revolutions at 3.4v. With this 2v range, the potentiometer is not really ideal, as it will change suddenly rpm with the slighlest touch.
                    I need something...
                    12-07-2022, 11:00 AM
                  • Bartoloni
                    Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                    by Bartoloni
                    Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                    everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                    there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                    replaced the capacitor (330) and the inductor (R15) without any change
                    any idea? very thank you!
                    input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                    12-09-2024, 12:42 PM
                  • badcap111
                    How to read inductor specs?
                    by badcap111
                    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
                    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
                    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
                    09-12-2023, 01:25 PM
