Mosfet V_GS question.
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    I've made a another little project, including a LCD. This time, I thought it could be interesting to control the back light with PWM. I'ts done with a PWM signal from a Atmega 328 MCU, which goes to a IRFZ46N mosfet. It is working like a charm.
    My question is, IRFZ46N V_GS (th) voltage is defined 2-4v. Its a power Mosfet. "Logic" Mosfet's usuallt has V_ GS (th) 1-2v.
    According to other forums, it should not be possible to drive a IRFZ46N from logic level, but it seems to work. The logic level is 5V.
    What do miss ?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Mosfet V_GS question.
    5v on a 4v Vgs(th) mosfet is a bit on the edge, but your backlight presents a very low load, so it doesn't matter much. A few mW extra dissipated in the fet... Unless your device runs on batteries i wouldn't be concerned. When you get to switching high currents, that's where the level of the gate drive comes into play.
    A working TV? How boring!
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      No no, it runs from mains.
      What is the recommended voltage for Vgs(th) ?
      • PeteS in CA
        • Aug 2005
        • 3580
        • USA, Unsure of Planet
        Not clear what is puzzling you. A standard MOSFET will turn on at ~4V, but at 5V G-S it may or may not be in saturation. A "Logic-Level" MOSFET will be in saturation at 5V G-S. If the gate drive signal from your MCU is 5V, a standard MOSFET will be on, and the Drain current in your circuit may be low enough that not being in saturation (if that is the case) isn't causing a problem. That your switch MOSFET is on the primary (mains) side of the circuit doesn't mean much, unless it gets ~300VDC on the Gate, in which case you'll have a brief, bright, noisy and bad-smelling event.
        PeteS in CA
        • Rob Northen
          • Jan 2010
          • 137
          • Denmark
          What is puzzeling is these line from the IRF46N datasheet:
          -------------------------------Min Max Units
          VGS(th) Gate Threshold Voltage 2.0 ––– 4.0 V
          I read it as max 4.0v. But I've been told that is not correct, and I read it wrong.
            You may want to read this to understand the Vgs and Vgs (th).Page 22 of Fairchild app notes:
            Threshold Voltage (VGS(th))
            This is the minimum gate bias which enables the formation of the channel between the source and
            the drain. The drain current increases in proportion to (VGS–VGS(th))2 in the saturation region.
            • PeteS in CA
              • Aug 2005
              • 3580
              You may have spotted the point of confusion, bud. The V(GS) th specifies the range in which the part is guaranteed to start to turn on. The absolute maximum G-S voltage is 20V (Datasheet front page). Also, a MOSFET is not a perfect switch, either fully on or fully off. There is a voltage range between its turn-on threshold and the gate voltage at which it goes into saturation. In that range the MOSFET can be used as an amplifier rather than a switch.
              PeteS in CA
                Agree, It confuses a lot of people when they see the MIN and Max numbers of Vgs(th) without looking at the Vgs spec.
                • Rob Northen
                  • Jan 2010
                  • 137
                  • Denmark
                  Thanks to both of you, it made more clear. I did notice the Vgs +-20v, but VGSth
                  comfused me...
                    In a robot competition, we used a power MOSFET to control a pump. The IO output gave 3.3V but this was fine. The MOSFET dropped about 0.5V at 500mA so this is about 1 ohm rds(on). Was just a prototype .
                    • prodigy83
                      MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
                      by prodigy83
                      My reference only: TT10141.
                      Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
                      Mosfet specs are as follows:
                      Chip markings:...
                      03-12-2024, 01:38 PM
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • Nooy
                      VGA MOSfet permanently shorted and loss of MOSfet pad
                      by Nooy
                      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                      02-14-2024, 02:26 AM
                    • AppleLover123
                      Asus X712EA 3 volts after the first mosfet
                      by AppleLover123
                      Hey guys,
                      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                      Now i thought something...
                      12-15-2024, 07:49 AM
                    • MicroSMD Lab
                      by MicroSMD Lab
                      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                      01-10-2024, 06:36 AM
