what is this component
  • xaviero1412
    • Apr 2009
    • 56
    dear all,
    i want to know, what is this component name ???
    thanks
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: what is this component
    What's it from and is there a board marking nearby? Would help to post a bigger picture.
    • xaviero1412
      • Apr 2009
      • 56
      this part from laptop, samsung nc108...
      there no any code-mark , or any schematic... one of them is burn-out... so this is the same part as the burn one.
      thanks for reply b70029
      • b700029
        Banned
        • Sep 2010
        • 640
        Post a clear picture including it and the parts nearby.
        I can't find a schematic and if there's no marking it'll be difficult, the best I can do is a guess based on what's connected to it.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          I see at least 8 parts on that board. Which one are you asking about? Is it the 6-legged part marked "D9DA" ?
          Please draw an arrow on the picture pointing to the one you mean or such.
          -David VanHorn
          • xaviero1412
            • Apr 2009
            • 56
            thank you all for the attention,
            the case is solved, accidentally i've found same part from another motherboard.
            • dutchgaucho
              Please help to identify component with marking eHFFH
              by dutchgaucho
              Dear BadCaps colleagues,
              I'm working on a HP Omen 16-WF0894ND. Won't turn on. Battery is charging and 3 and 5V rails are present.
              However, I located PU1801 that's only outputting 0.37v as soon as the power button is pressed. Weird voltage imo, although there's no short after the coil. Chip aint getting hot either. Since no diagram is available, I can't really determine what this rail is for, but I assume it might be a PCH PWR rail. Please help me to identify:
              Chip marking eHFFH
              Board model: LA-M783P
              Please also see pictures attached.
              Today, 02:41 AM
            • AquaMan Ua
              Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
              by AquaMan Ua
              Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
              I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
              08-26-2025, 09:07 AM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • ali2380
              ASUS VIVOBOOK TP470EZ
              by ali2380
              HI DEAR FRIENDS,
              I NEED A BOARDVIEW OF ASUS VIVOBOOK TP470EZ
              SO COULD YOU PLEASE SEND IF YOU HAVE IT?
              08-16-2025, 03:21 AM
            • lrservicios
              hp OMEN 25L GT15 Request
              by lrservicios
              Hi dear Forum !!!
              I ask gently for a Bios repair or Clean ME BIOS clean DUMP for a HP Desktop OMEN - 25L
              Exact MODEL is: GT15-0004ns S/N: 8CG21252CQ
              I ATTACH original Bios...
              08-11-2025, 12:34 PM
