GM Detector
  • barry wilkins
    • Aug 2009
    • 172
    GM Detector
    I have been experimenting in making a radiation detector using a diode instead of a Gieger Muller Tube. Has anybody tried to do this ? My latest circuit did not seem to pick anything up ,this has a Hamamatsu photo diode covered with aluminium foil.
    Perhaps there not enough gamma radiation where I live to get a result !
    Any thoughts on this ?
    Barry Wilkins
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    Re: GM Detector
    Is that even possible?
    There must be a reason why people generally use tubes instead...
    -David VanHorn
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: GM Detector
      Radiation tends to damage semiconductors.
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • Baste
        MBR3045CT and SR3045LCT Schottky diode testing help.
        by Baste
        Hello experts,
        Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
        Aneng ST182 Meter.
        Diode mode.
        MBR3045CT:
        Diode mode
        Pin 2-1 - 0.150v
        Pin 2-3 - 0.150v ...
        10-21-2025, 06:14 AM
      • NicRac
        monowheel repair,Is the diode the problem?
        by NicRac
        Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
        First of all, I am new here. Therefore I will shortly introduce myself.
        I am Nico and currently I study Physics.
        In my freetime I like to build and repair stuff. Especially big battery's.
        A few years ago I got myself an electric unicycle, monowheel or however you call that.
        The battery bms was broken so I replaced and resolder that. Nothing big.
        I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
        07-26-2024, 06:13 AM
      • dennis_elx33
        NO BODY MARKING Diode
        by dennis_elx33
        Hello Everyone,
        I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
        While compared to the reading of another diode from the next channel it won't read at reverse bias.
        Now the problem is; it does not have any body marking.
        So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
        What do you think is this diode?
        Can you please suggest what part number can i use to replace this faulty diode instead?
        Hoping that you...
        06-14-2024, 12:36 AM
