"Upgrading" a Weller WECP-20?
  • DMCrimson
    • Feb 2012
    • 58
    • Finland
    As I mentioned in other thread, there's some weller trouble - so I thought I'd ask: Would it be possible to mod a WECP-20 (50W) with 85W transformer to supply a WP80 soldering iron? I know the pinout on the iron and supply do not match, but that's just a small thing. The control board seems to be ok for more watts than just 50.
  • thomas_rudloff
    • May 2012
    Re: "Upgrading" a Weller WECP-20?
    Drill the missing 7th whole in the connector. As long as you do not require 100% duty cycle the WECP can handle this. It might have some little hum while heating.
    • DMCrimson
      • Feb 2012
      • 58
      • Finland
      That thought hadn't even crossed my mind Will have to try that - as sourcing a suitable transformer has failed.
      • DMCrimson
        • Feb 2012
        • 58
        • Finland
        Hehe, finally got around to do this, though I didn't have a drill to work with. Just plain soldering iron, with some stiff copper wire wrapped on it - on I went. The transformer indeed does hum a bit, and stops at some point, but this could be that I had just WP80 to go with. Overall - satisfied. Still need to try and source that transformer Gosh year and a half
        • DMCrimson
          • Feb 2012
          • 58
          • Finland
          Anyone with PU80? care to pop it open and check part number on controller pcb and trans? Pictures would be cool too
          • redwire
            • 3912
            Found a schematic of the Weller PU-81, but no success on the 80.
            • DMCrimson
              • Feb 2012
              • 58
              • Finland
              Looks like I need to do a comparison on the pcb against that. Any info on the transformer?
              • redwire
                • 3912
                Soldering irons don't run 100% duty cycle, you can under-spec the transformer i.e Weller PU120T (for WTCPT) is a 60W unit with a 40VA transformer.
                I am confused with the part numbers we are talking about
                WS 81 - 80W temp. controlled soldering station set (240VAC mains)
                WS 81T - 80W analog temp. controlled soldering station set (240VAC mains)
                PU 81 - analog temp. control power unit (base PSU)
                WSP 80 - soldering pencil
                The part number: 810 87487 29 TRANSFORMER 230/24VAC 80VA
                So it looks like an 80VA transformer is used. Run the 50VA one you have and see if it runs too hot.
                • DMCrimson
                  • Feb 2012
                  • 58
                  • Finland
                  Ooops, my bad for not being clear enough... I'm running a WSP80 with WECP-20, which is a 50VA thingy. And if I push temp over 350 °C it starts chirping a bit
                  • DMCrimson
                    • Feb 2012
                    • 58
                    • Finland
                    Just a thought: I do have a second WECP-20 unit - could I just use the transformer from that and use them two in parallel? They would then share the load, methinks. Someone wiser, put a word
                    http://solderman.dapj.com/2005/09/tr...-parallel.html
                      • 31286
                      that's risky,
                      if you get them out of phase they will burn-up or take your breaker/fuse out.
                      and if they arent 100% the same you will need a low value resistor on each output.
                      24v is hardly a rare voltage you know.
                      how many amps do you need?
                        • 31286
                        http://www.rapidonline.com/Electrica...2V-12V-88-3938
                        http://www.rapidonline.com/Electrica...2V-12V-88-3947
                        http://www.rapidonline.com/Electrica...-0-12V-88-5198
                        i'd go with a toroid type - it took under a minute to find those.
                        • DMCrimson
                          • Feb 2012
                          • 58
                          • Finland
                          well, does that have 5V tap? Those amps should be the same, so parallel could cut it? Tho I'd need to make a new chassis for that combo ;D
                            • 31286
                            no 5v tap.
                            no 5v on the original either i suspect, more like 7 or more to feed a regulator.
                            if yu u use a 12-0-12 output to get 24v and use the center-tap to feed a regulator you get 5v.
                            • DMCrimson
                              • Feb 2012
                              • 58
                              • Finland
                              That might do it. But first I'll try that parallel configuration, If it fails, I do have another control board and a case to use with toroidal
                              • learnmore
                                Help choosing replacement transformer for Levoit 600S SMPS
                                by learnmore
                                Hello Community,
                                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                Peace
                                LM...
                                11-04-2025, 09:35 AM
                              • ohren
                                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                by ohren
                                Hello!
                                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                Measured voltages with no load:
                                After rectifier diodes
                                12V: 6.17 V
                                5V: 5.67 V
                                Secondary transformer pins AC measurement (really don't know if this says anything)
                                12V: 2-2.5 V
                                5V: 1.04 V
                                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                03-18-2023, 10:33 AM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
                              • dennis_elx33
                                3PHASE STEP-DOWN Transformer in Check
                                by dennis_elx33
                                Hello All,
                                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                Problem statement: Power tripped Off
                                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                Action Done:
                                1) Replaced the faulty parts with good spare.
                                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                12-02-2024, 06:52 AM
                              • unimatrix93
                                Replacement transformer for Samsung fridge
                                by unimatrix93
                                Dear forum
                                My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                07-14-2025, 02:16 AM
