Let's See What You Got!
    master hoarder
    • May 2008
    • 12175
    #41
    Re: Let's See What You Got!
    Originally posted by shovenose
    I live in Fairfax too the other Fairfax
    Yeah, I always find it kind of funny when I see your location is Fairfax.
    I'll take a pic of my workbench/desk when it's clean right now it's embarrasing!
    A messy bench is a good bench - means you're using it. If it's too clean, then you know it's all show and no go .
    Originally posted by ELItheICEman
    Noteworthy features: the fan, soldering iron, glue gun, etc. are controlled from the 386 laptop on the shelf (using Qbasic) the bigger shelf has a 24v power supply and an ATX power supply that are also controlled from the laptop.
    That is pretty cool.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8702
      I really need to set up a bona fide workbench... right now I just have a mess everywhere, sticking equipment wherever there's space... not pleasant reaching for tools, etc.
      Not to mention my workspace tends to be my lap or floor when working with high voltage... Not OSHA compliant at all! Just not enough table space...
        master hoarder
        • May 2008
        • 12175
        #43
        I always work on the soft carpet floor in my room and regularly solder in my lap. As a result, my back hurts a lot less than when sitting in front of a bench. The only thing that hurts sometimes is my hips, usually after 3 to 4+ hours of sitting. Just snap them at the end of the day, though, and all is good again. Back pain can be a bitch, so I do try to avoid it.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8702
          The problem of working on your lap is that going to reach for tools means having to set the workpiece aside... annoying. I really need to get some real workspace ...
            master hoarder
            • May 2008
            • 12175
            #45
            ^ Hasn't happened to me. Then again, I have a mini bench table I built myself that usually has all of the tools I need on it so everything is just an arm's length away from me.
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              Too close for comfort for me. I value my crown jewels a bit more.
              I do all my soldering on the kitchen floor. Someday, I will have a "proper" work area.
              --- begin sig file ---
              --- end sig file ---
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I do soldering on my workbench. Actually, its always got stuff piled ontop, so, I'm soldering stuff ontop of stuff xD
                I have never burned my balls with solder , but I do have a scar on my leg from a splotch of solder that fell. Now, I always make sure that my legs aren't under what I am soldering. (That burn hurt like heeeeeeeeeeeeeeeeeeeeeeeeeelllllll!)
                Muh-soggy-knee
                  master hoarder
                  • May 2008
                  • 12175
                  #48
                  Lol.
                  You need to get the balls of steel
                  That's one of the things I always try to avoid. Even when I'm careful, I still happen to drop solder whiskers every now and then.
                  Ouch. I think I have been lucky way too many times now. I must have dropped hot MOSFETs and coils on my lap at least 10 times now. Luckily, each of these times, I was wearing long pants and didn't get burned.
                  Also, one time I was removing a big audio connector from a motherboard in. Instead of using hot air or similar, I took a bunch of leftover balls of solder and clumped them together into 1 big ball, then used that to cover almost all of the pins on the audio connector to remove it. As soon as I pulled the audio connector away from the board, the hot solder fell thought the holes as well. Luckily (again) I was working on a bench and I didn't have my feet under the motherboard. If I did, I would have gotten burned with a lot of solder. The big solder ball I was melting was about 1-2 cm in diameter - a lot of solder, basically. When that thing splat on the ground, it made a nice sheet of flat solder about 4 cm^2.
                  • 1supertech
                    • Apr 2012
                    • 384
                    Originally posted by Peter9DO
                    So, I figured we all are wired to the same tune! I take great pride in my work station and bench. I know it's not the most impressive but it's mine and I love it! So, I figured, you guys feel the same about your bench and work space so, LETS SEE IT!!!!!! Take a look at what I'm working with! Can't wait to see what you guys are rocking out with! (it's a little dusty...lol!).
                    Please don't take this posting as me bragging about what I have. I'm very humble and I don't think my workspace is anything to write home about. But I learned a lot about setting up my work area by seeing other peoples shops and asking questions. I think posting your work space would be great to a beginner to open up conversation as to why, what and how you set up your shop the way you did. Also, all of us geeks appreciate this kind of stuff!
                    These pictures are of my home office, I also have a warehouse that I store a lot of the bigger items. As you can tell from the pictures, it's not a very big room so a warehouse was important for me to obtain. Especially when it's a friend of the families and is willing to let me use it for free! lol!
                    I have only been repairing monitors for a year my shop isn't as elaborate as most of you but I like my shop
                    • blownvp
                      • Jul 2013
                      The first 3 photos is where I fix devices.i don't do many repairs lately just the odd bit of equipment that's why most of the gear is in the cupboards.the second 3 photos is the room where I fry electronic devices lol.cheers darren.
                      • capwizard
                        • Jun 2016
                        • 1991
                        After the fire department gave me two, three tickets then I worked hard to clean up, this is my best result. I think I need to go to a neurological hospital for treatment. Can somebody please help me?
                        But I am not the worst. Once I went to an elegant lady's house repair TV. Her house is full of garbage, I'd to walk on 1 inch deep papers, bags on the floor. When she spoke to jaw drops me, she didn't feel anything wrong. Her attitude and appearance are still so generous and noble.
                        I think I got a friend.
                        • llonen
                          • Sep 2014
                          • 495
                          • hampshire
                          #52
                          Well I was supposed to put up a couple of pics of the workshop, and I really did mean to tidy, but last year was not a good tidying year and this year looks no better lmao.
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
                          • Eniaro
                            Bench test a series X
                            by Eniaro
                            How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                            06-17-2025, 01:46 PM
                          • rabsonnjala
                            LENOVO IDEAPAD 100 works only on bench power supply
                            by rabsonnjala
                            Hie I have a Lenovo laptop
                            Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                            it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                            below are my readings
                            with the original charger only
                            JBATT1
                            PIN1 0.22V
                            PIN2 0.22V
                            PIN3 0.45V
                            PIN4 0.45V
                            PIN5 O.43V
                            PIN6 0V
                            PIN7 GND
                            PIN8...
                            11-20-2021, 08:32 AM
                          • Geeker007
                            Friend messed up my laptop motherboard while working on my bench
                            by Geeker007
                            Hi All,
                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                            I have not tried putting...
                            06-16-2025, 01:40 PM
                          • Crystaleyes
                            Bench PSU question
                            by Crystaleyes
                            Hi all.
                            Looking for some help regarding the workings of this unit.
                            Some time ago I picked up a digital bench power supply from the local flea market here in Rio. It's a 'Sincler SPS 3015/D' which I imagine is 30V, 1.5A 'Digital'.
                            Even though it would turn on and show a display, it wasn't working, and no matter how hard I have looked, I've found no reference let alone any kind of schematic. I imagine it is from the late 70's or early 80's? I can only assume that all the components are to the original specs although it had clearly had prior work done so it 'is' possible...
                            11-12-2024, 05:05 AM
