Gotta love OST c(r)aps
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Had a machine with an ECS board in today, bloated 6.3v 3300uF OST cap on the 5vsb. The mobo is full of OSTs but luckily this was the only bad one, and it's a Sempron board so it doesn't see much abuse. PSU was a Premier full of crap caps too, but everything looked okay and 5vsb was in spec, so i just slapped a Rubycon on the mobo and she fired right up. Likely what happened was that the owner left a phone or mp3 to charge off USB, and the lackluster filtering of the PSU itself left the OST crap eat all the ripple, so the cap proceeded to cook itself.
    In fact the complaint was of something else - the system wouldn't power up, front panel unresponsive. However, when the top of the case was pressed it would work. The issue was quickly found - the DVD drive was very long and pressing on the motherboard, shorting it out to the case. So i just moved it to the uppermost slot.
    The "unresponsive front panel" was actually a bad power switch, i wired the reset switch for power. Now he can pretend he has a brand name PC.
    Coming back to our bloated OST, i tried to blow it up by reversing it at 5v. No go, it didn't even heat up. Same thing at 12v. POS went so bad it won't even blow up. Now ain't that sad.
    A working TV? How boring!
  • c_hegge
    • Sep 2009
    • 5219
    Re: Gotta love OST c(r)aps
    It was probably open.
    In any case, though, you're lucky it bloated, since OST (Only Some Trash) rarely bloat when they fail.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      It wasn't *that* open - finally managed to pop it using a 40v supply. Didn't do anything spectacular tho - it just went pffffff.
      • c_hegge
        • Sep 2009
        • 5219
        Best caps to explode are Sacon FZ. The vents aren't cut very deep in them, so when they fail, they always go
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Don't have any Sacon, but i do have some oldschool GSC (Global S*** Corporation) with no vents. But it's the middle of the night here and those WILL make some noise so i won't pop them now. They should make great New Year's firecrackers.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            they spew chunks too... they are the most caps I have ever seen.
            I have a couple ones not bloated... but im not bombing it... my test bench is a big enough mess as it is.
            sigpic
            (Insert witty quote here)
            • Agent24
              I see dead caps
              • Oct 2007
              • 5008
              • New Zealand
              Yeah what is up with that? Do they think their product is so stable it doesn't even need a reset button? Weird...
              -David VanHorn
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                No, but they save $.02 by not including it.
                • yavqq
                  Sony XBR-65x900F troubleshooting unresponsive TV
                  by yavqq
                  This all started a few days ago when out of no where the TV appeared unresponsive. Pushing the power button did not do anything and there was no standby light active. However, holding the power and volume up button while plugging in the AC power did show a steady solid green light. Still no display and no further activity from there.
                  After some research I did some measuring of the common voltage points..
                  Main Board Connector
                  Pin 02 "BL_ON": 0.00V
                  Pin 03 "POWER_ON": 3.47V
                  Pin 05 "STBY 3.3V":...
                  02-09-2023, 10:14 AM
                • DemonBG
                  Samsung QN82Q60R - locks up / Crashing / Unresponsive
                  by DemonBG
                  Picked this one up a few days ago. QN82Q60R. Screen works perfectly and sound works but after booting, the unit randomly becomes unresponsive to input (though whatever is on the screen will continue to play).
                  Tried standard reset - no improvement.
                  Tried service mode reset - No improvement
                  Service menu is difficult to navigate as the unit regularly crashes / locks up which means i have to restart the set.
                  Something i have also not seen before is that sometimes (not always) when i enter the service menu, i get an error "ERR by empty version Data....
                  03-16-2024, 09:49 PM
                • brav1ez
                  ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
                  by brav1ez
                  I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
                  I’ve tried:
                  - CMOS reset
                  - Removing the SSD/HDD
                  - Reseating RAM (removing each stick individually stops boot completely)
                  - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
                  With...
                  09-07-2025, 10:47 AM
                • gusto
                  Asus E406MA unresponsive
                  by gusto
                  NTB Asus E406MA. NTB worked great, but one day it wouldn't turn on. After pressing the button on the keyboard, nothing happened (just darkness). Since the NTB does not have a CMOS battery, disk (eMMC) and RAM integrated on the motherboard, I disconnected the large battery and connected the NTB to a 19V adapter. After pressing the button on the keyboard, nothing happened (just darkness).
                  I measured the voltage on the MB and found that it was fine, 19V (see picture).
                  I would also like to check if the power button is fine, but I can't find the correct pins on the keyboard connector....
                  12-17-2024, 05:47 AM
                • KYBOSH
                  Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
                  by KYBOSH
                  This found its way to my workbench this week.
                  The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
                  Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
                  The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
                  This reminded me of the eufy floodlight...
                  09-06-2024, 09:09 PM
