Geting information about a bulb
  • playman
    • Jan 2011
    • 252
    I have some bulbs here from a christmass decoration, now this season has started again(feels just like it was yesterday)
    So my question is.
    How can I find out it's Wattage Amperage and Volt, if it has no reading on it?
    isint there some way to mesure it?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Geting information about a bulb
    You can measure the resistance and make an estimate of the power which should let you apply the right voltage without burning it out.
    • playman
      • Jan 2011
      • 252
      thanks for that b700029
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        If it's an incandescent bulb, measuring the resistance with a meter is useless.
        The filament actually changes resistance when it heats up and glows, and is a lot higher when running than when cold.
        I don't know if there is a formula you can use to calculate the normal resistance from the cold resistance (There very likely is)
        But as it stands now, your resistance measurement will not give you accurate information about the bulb.
        -David VanHorn
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Only by destructive testing.
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            There is but you'd have to know things like the material, the material's electrical properties, the diameter and the length.
            - Dr Seuss
            • playman
              • Jan 2011
              • 252
              Well I guess this is a lost case, damn it.
              well thanks every one for your input.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                What are you trying to do anyway?
                - Dr Seuss
                • dumpystig
                  • Jul 2011
                  • 485
                  Try it connected to a couple of AA's, then 4 etc. - gradually increase the voltage until it illuminates but at a level that is not too bright otherwise you will burn it out.
                  System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5085
                    • New Zealand
                    What does the bulb look like? (photo?)
                    What power source does the decoration run from?
                    How many bulbs are in it and how are they connected (series, parallel etc)?
                    You might be able to find out more about the bulb by taking these things into account
                    Can you find the decoration for sale anywhere? Can you ask them if they sell spare bulbs? If so, perhaps they know the specifications.
                    -David VanHorn
                    • repair-it
                      TOSHIBA DLP 52HM95 How to reset timer module on bulb
                      by repair-it
                      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                      10-11-2023, 07:18 PM
                    • ezenia
                      LUMIMAN Smart Bulb IC ID?
                      by ezenia
                      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                      04-28-2025, 05:56 PM
                    • JimBanville
                      Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                      by JimBanville
                      I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                      Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                      01-24-2023, 07:49 AM
                    • sew333
                      Light bulb flicker
                      by sew333
                      Hello. I have an question about my bulb in room. Weather is normal,no storm etc. Today first time it flickered for 1 second. It happened when i close door in my room ( no more air )
                      Bulb looking like that:
                      Is this problem with electric in my house or it was bulb? It flickered ( black ) for 1 second and its fine. Should i worry? All deviced and pc working ok.
                      My mother turned oven 2 hours ago,maybe something because of that?Bulb flickered 5 minutes ago....
                      07-17-2021, 04:22 PM
                    • dreico33
                      Mesure CPU, GPU APU VCore.
                      by dreico33
                      Hellow guys,
                      I have came across many times to mesure VCore Coils or capasitors of a CPU GPU and APU. How we can take acurate mesuraments on these components when the same componetes most of time ( if not always) will have close to 0 resistance to ground,very low voltage drop ( in diode mode) it will beep in continuity mode. I mean whatever mesurement i take i can not be sure if we have a short or just low restistance ( very low sometimes),. How we can seperate a short from normal low restistance components?
                      Τhank you for your time....
                      05-21-2024, 01:58 PM
