How do toggle switches work?
  • mockingbird
    • Dec 2008
    • 5488
    I've got a board here with a switch, it's got a three pin switch... The AC adapter is low mA and 20 volts. I can't seem to get any voltage past the two DC pins from the AC adapter port that are soldered in the board...
    Now the positive pin on the back of this relatively simple board travels to one of the three pins of the switch. My understanding is that when the switch is toggled, it connects the first and second pin (I don't know what the third pin is) and the secnd pin is jumpered to the rest of the board somehow...
    ...yet whether the switch is toggled or not, I'm only reading 20V when the probe is on the first pin of the switch...
    Is the switch defective?
    I ask because the board doesn't power up, no voltage even before the the small either tantalum or ceramic capacitor near the two mosfets.
    Here is the datasheet of the exact switch:
    It's the switch pictured at the very top right corner.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: How do toggle switches work?
    They are essentially throw switches. If you add a magnetic coil or solenoid and run current through them they become relays.
    what model?
    It will tell you in the data sheet what function it does when the switch is in a position?
    Remove it and do a continuity test on it.
    I've had broken switches before, so it's not uncommon. The springs and slide plates wear out, and they get stuck in the wrong position.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      funny, I just had an spdt switch I bought DOA on me today. yes, switches do break, and break often.
      sigpic
      (Insert witty quote here)
      • mockingbird
        • Dec 2008
        • 5488
        So the voltage is only showing on the first pin of the switch (The shortest one). The way I understand how this switch works, is that when it's switched on, it jumpers the first and second pins together, and the second pin passes on the voltage to the rest of the PCB. So should I just jumper the shortest and middle pin to see if the switch is broken?
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          I included a image to help you visualize.
          My pc
          CPU : AMD PHENOM II x4 @ 3.5Ghz
          MB : ASUS M4A89TD PRO USB3
          RAM : Kingston ValueRAM 16gb DDR3
          PSU : Cooler Master 850W Silent Pro
          GPU : ATI Radeon HD 6850
          • mockingbird
            • Dec 2008
            • 5488
            Ah, beautiful... So it is just jumpering... So as suspected, since the second pin is getting no voltage in the ON position, the switch is probably dead...
            Question... Why have a third "NO" pin for OFF? Why not just leave it not jumpered? Is this for continuity of ground when the AC Adapter is plugged in and it is off?
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              I believe they connect the unused pin to The pcb for support as for them been connected together more pad = more strength.
              As far as I can see it has no other benefit.
              My pc
              • mockingbird
                • Dec 2008
                • 5488
                Great... Newark seems to stock these switches... Now it's just down to getting the exact same one... Ouch, $5 for a switch?
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  yea switches can be costly I shop round.
                  My pc
                  • cmj21973
                    • 267
                    QUOTE=mockingbird;195649]Great... Newark seems to stock these switches... Now it's just down to getting the exact same one... Ouch, $5 for a switch?[/QUOTE]
                    Ususally the sliding/rocking contact gets fouled with gunk or fried from arcing.
                    Depending on the switch's size and if you can't take it apart, it's best to pay $5 and save yourself some trouble.
                    Or, you could scavenge/recycle a switch from something else.
                    P.S. Just seen the datasheet for your switch. Epoxy filled = toss when broke
                    • SluggerB
                      Help making a switch work the opposite way with a relay
                      by SluggerB
                      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                      02-07-2025, 07:57 PM
                      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 05:30 AM
                    • CapLeaker
                      Poly VVX-250 VOIP POE problem not booting fix
                      by CapLeaker
                      I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                      Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                      11-25-2023, 10:46 AM
                    • BOSCHNJAK
                      by BOSCHNJAK
                      ABOUT ME INTRODUCTION FILE
                      2
                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                      2022 BEV, PROJECT ?
                      2021 BEV, PROJECT ?
                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                      12-28-2023, 02:09 PM
                    • madan1
                      Cisco catalyst 2960c POE
                      by madan1
                      Hello everyone.
                      Got a catalyst 2960 from the usual scrapyard - ebay.
                      It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                      Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                      Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                      The switch fails to boot due to the following POST error:...
                      12-19-2024, 09:34 AM
