Hey guys in one of the posts here someone (can't remember who) mentioned that in some cases lowering ESR can be a bad thing so I'm wondering in which cases that might be since everyone here suggests low ESR caps for replacements.
Lowering ESR can be bad?
Re: Lowering ESR can be bad?
Probably PCBONEZ.--- begin sig file ---
--- end sig file --- -
It depends on the circuit.
With switching PSUs, you DON'T want to change the ESR too much. Reason being is that the output filters in these power supplies are tuned circuits built to filter certain frequencies that the PSU produces. Change the ESR too much, and that tuned circuit may become unstable or pass much more ripple and noise than it should.
Of course, some PSUs are more tolerant than others. LCD monitors and PSUs with very small or no inductors in the filtering circuit are usually more tolerant when you use caps with lower ESR that the original ones. In contrast, PC PSUs almost always are not. They will still likely work, but they will be passing more ripple.
With motherboards, it depends where the caps are located. Caps in CPU VRM can safely be replaced with ones with much lower ESR without side effects. In fact, this is one place where very low ESR is beneficial.
Outside of VRM, it can be hit-and-miss. In most cases, caps with lower than the original ESR will likely work fine too.Comment
I disagree. Lowering ESR won't necessarily change Xc, capacitative reactance. Of concern to designers is the inductive reactance of the secondary which is reflected back into the primary, and is important for proper selection of the switching device. I do agree that arbitrarily changing part values in a complex smps is not a good idea.Is it plugged in?Comment
I noticed once that replacing cheap caps like Teapo and CapXon with NCC and Nichicon low ESR caps increased ripple.
It was in the output of a PC PSU and is probably somewhere in the forum.
This seems to support the argument that these circuits are tuned to parts that have specific characteristics, even if they are of poor quality.
So the burden is on us to find stable, reliable caps that operate very similarly to the cheapies. Except for the short lifespan that is.
The More You Learn The Less You Know!Comment
I've seen an application circuit for an LT1184F CCFL controller which recommended an electrolytic capactior with an ESR of 0.5 ohms or greater at the Royer pin (pin 13) to prevent damage to the high side sense resistor in the controller due to surge currents at turn-on.
Basicially, this depends on the application.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Well I need to change 2 caps on a KTC 19" LCD power supply. The caps are located near the ribbon cables that go to the logic board. The originals (Capxcon) have ESR of 0.6 and I want to replace them with Panasonic M equivalents but those have ESR of 0.2. Would it be ok??Guns don't solve problems. I'll take 12
by AJ847.63eHi Folks,
Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't... -
Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
Securing a good thermal interface between...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:35 AM -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
10-07-2024, 06:02 AM -
by RukyConHello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
Anyway here is a quick overview of... - Loading...
